The DAP-3711 is the essential solution in providing connectivity to previously believed impossible-to-reach areas. Industry leading core technologies, especially designed for long distance coverage, bring high-speed connectivity to rural areas and challenging terrain equivalent to that of a wired connection.
- D-Link DAP-3711 - wireless bridge - Wi-Fi 5
- Wireless bridge
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 5 GHz
- Performance
- Bandwidth: 20 MHz , Bandwidth: 40 Mhz , Bandwidth: 80 MHz
- Power Over Ethernet (PoE) Supported
- PoE
- Power
- DC 24 V (PoE)
- 8.8 cm x 4.5 cm x 28.8 cm
- 600 g
- Wireless bridge
- 8.8 cm
- 4.5 cm
- 28.8 cm
- 600 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 867 Mbps
- NTP, DHCP
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- NTP, DHCP
- Frequency Band
- 5 GHz
- Max Range Open Space
- 5 km
- Performance
- Status Indicators
- Power, signal strength, WLAN, LAN
- VLAN support, Syslog support, MAC address filtering, firmware upgradable, Auto Channel Select (ACS), reset button, Time Division Multiple Access (TDMA), WDS access point, dustproof, waterproof, 8KV surge protection
- Encryption Algorithm
- WPA2, 128-bit AES
- Authentication Method
- Radio Service Set ID (SSID)
- IEEE 802.11i
Aerial
- Antenna
- Internal
- Directivity
- Directional
- Gain Level
- 15 dBi
- 1 x 1000Base-T - RJ-45 , 1 x 1000Base-T (PoE) - RJ-45
- FCC, IP66
- PoE
- Power Device
- Power injector
- Voltage Required
- DC 24 V (PoE)
- 15 Watt
- -40 °C
- 65 °C
- 0 - 90%
