D-Link 5G WI-FI 6 Mobile Hotspot
Quicklinx: GQ88WS00 Mfr#: DWR-2101
14 In Stock
£281.98 ex VAT
£338.37 inc VAT
D-Link enables enhanced broadband capacity, extremely low latency, high bandwidth, and faster speeds with the DWR-2101 mobile hotspot. The DWR-2101 is ideal for business and leisure travelers as it can support a wide range of international 5G bands.
  • Powerful battery life
    Equipped with a 5260 mAh lithium-ion battery, this mobile hotspot ensures extended usage times, allowing you to stay connected without constant recharges.
  • Seamless connectivity
    With support for 5G networks and Wi-Fi 6 technology, the DWR-2101 offers high-speed Internet access, ensuring fast and reliable connections for all your devices.
  • Advanced security
    Featuring WPA3 encryption, the most advanced Wi-Fi security protocol, the DWR-2101 provides robust protection against unauthorized access to your network.
  • Intuitive operation
    A built-in 2.4" touchscreen display makes managing your network settings and monitoring connection status effortless and straightforward.
  • Versatile connections
    Includes both a 1000Base-T RJ-45 connector and a Type-C USB port, offering flexible options for wired connections alongside its wireless capabilities.
D-Link DWR-2101 - mobile hotspot - 5G LTE
Mobile hotspot
External
Max Transfer Rate
1.6 Gbps
Mobile Communication Protocol
WCDMA, FDD LTE, TDD LTE
802.11ax, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
5260 mAh
11.9 cm x 7.2 cm x 2.35 cm
235 g
Mobile hotspot
External
Built-in Devices
2.4" touch screen display
Modem
Wireless
Max Transfer Rate
1.6 Gbps
Antenna
Internal
Wireless
Status display, DMZ support
IEEE 802.11b, IEEE 802.11g, IEEE 802.3ac, IEEE 802.11n, IEEE 802.11ax, Wi-Fi CERTIFIED 6
1 x 1000Base-T - RJ-45 , 1 x USB - Type C
SIM Card Supported
Nano-SIM x 1
Encryption Algorithm
WPA, WPA2, WPA3
RoHS
Lithium Ion
5260 mAh
11.9 cm
7.2 cm
2.35 cm
235 g
55 °C
10 - 90% (non-condensing)
Brand: D-Link
