D-Link 5G M2M VPN Wi-Fi 6 Router
Quicklinx: J7JCWS00 Mfr#: DWM-550-G
£295.33 ex VAT
£354.39 inc VAT
The D-Link DWM-550-G wireless cellular modem is designed for robust performance in demanding environments. With its six external detachable antennas, this device optimizes connectivity for both LTE and Wi-Fi, ensuring strong signal strength and reliable Internet access. The modem supports cellular protocols across multiple generations, including 3G, 4G, and 5G, making it versatile for various connectivity needs. This modem features a maximum transfer rate of 3.4 Gbps, ensuring fast data transmission for users. It operates in harsh environments, with a wide temperature range from -30°C to 70°C, and can handle humidity levels from 10% to 95%. With multiple layers of security, including various encryption algorithms, the DWM-550-G strengthens the protection of your network without compromising performance. Its Plug-and-Play capability allows for quick setup, making it a practical choice for both personal and industrial applications.
  • Reliable connectivity
    With six external detachable LTE and Wi-Fi antennas, this modem ensures optimal signal strength and reliable Internet access for varied applications.
  • High-speed data transfer
    Achieve maximum transfer rates of up to 3.4 Gbps, enabling efficient data handling for multiple users and devices.
  • Robust environmental durability
    Engineered for harsh conditions, it operates efficiently within temperatures from -30°C to 70°C and withstands humidity levels of 10% to 95%.
  • Comprehensive security features
    Equipped with advanced encryption algorithms, including WPA3, this device ensures safe and secure connections for all network activities.
  • Easy installation
    The Plug-and-Play setup makes it simple to get the modem operational quickly, allowing users to connect without extensive configurations.
D-Link DWM-550-G - wireless router - WWAN - Wi-Fi 6 - 5G, 4G, 3G - wall-mountable
Wireless router - wireless cellular modem
Enclosure Type
Wall-mountable
Mobile Communication Protocol
FDD LTE, TDD LTE
Generation
5G, 4G, 3G
Cellular Band
5G n1, 5G n3, 5G n5, 5G n7, 5G n8, 5G n20, 5G n28, 5G n38, 5G n40, 5G n41, 5G n71, 5G n75, 5G n76, 5G n77, 5G n78, LTE B1, LTE B20, LTE B28, LTE B3, LTE B32, LTE B5, LTE B7, LTE B71, LTE B8, LTE B38, LTE B40, LTE B41, LTE B42, LTE B43
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz / 5 GHz
Performance
Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 1201 Mbps
Network / Transport Protocol
HTTP, HTTPs, PPTP, L2TP, IPSec, PPPoE
Routing Protocol
GRE, PPPoE
Remote Management Protocol
SNMP, SNMP 1, SNMP 2, SNMP 3, CLI, SFTP
Band steering, WIDS, RADIUS support, Syslog support, designed for use in harsh industrial environments, BGP, CLI management, DHCP relay, DHCP server, DMZ support, dynamic routing, DynDNS, FTP support, IGMP support, IPv4 support, IPv6 support, NAT loopback, No-IP DDNS, NTP support, OSPF, port forwarding, port-based VLAN, QoS, remote reboot, remote reset, RESTful APIs, SFTP support, SNMP support, static routing, system log, tagged VLAN, ToS, virtual server support, VPN passthrough, web-based UI, failover support, ICMP health checking, load balance network mode, NAT support, Wi-Fi 6 technology, corrosion-resistant, zinc-plated steel case, bridge mode, SMS alert
IEEE 802.11a, IEEE 802.11ac, IEEE 802.11ax, IEEE 802.11b, IEEE 802.11g, IEEE 802.11h, IEEE 802.11n, Wi-Fi CERTIFIED 6
16 cm x 12.5 cm x 3.5 cm
Wireless router
Enclosure Type
Wall-mountable
Wired, wireless
Frequency Band
2.4 GHz / 5 GHz
Performance
Routing Protocol
GRE, PPPoE
Encryption Algorithm
AES, WPA2, TKIP, WPA2-PSK, WPA3-Enterprise, WPA3-SAE, WPA-PSK
Wi-Fi Rating
AX1800
IEEE 802.11a, IEEE 802.11ac, IEEE 802.11ax, IEEE 802.11b, IEEE 802.11g, IEEE 802.11h, IEEE 802.11n, Wi-Fi CERTIFIED 6, Plug and Play, UKCA, WPA2
Status Indicators
4G, power, signal, SIM status, status
Communications
Wireless cellular modem
FDD LTE, TDD LTE
Generation
5G, 4G, 3G
Cellular Band
Max Transfer Rate
3.4 Gbps
Internet of Things (IoT)
Communications Type
Product-to-product
WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Antenna: 4 x SMA , Antenna: 2 x SMA
Expansion Slots
2 (total) / 2 (free) x Nano-SIM
Aerial
Aerial
External detachable
Antenna Qty
6
Configuration Details
4 detachable external LTE antennas, 2 detachable WiFi antennas
External power adapter
Installed Qty
1
3-pin terminal block
1 x network cable
16 cm
12.5 cm
3.5 cm
-30 °C
70 °C
10 - 95% (non-condensing)
Brand: D-Link
