The D-Link DWM-314-G modem provides wireless connectivity with support for 5G NR and 4G LTE, enabling Internet speeds up to 3.4 Gbps. This external modem features a robust design with four external detachable antennas, ensuring signal reception in various environmental conditions ranging from -30°C to 70°C and humidity levels of 10% to 95%. With dual SIM card support and a variety of connectivity options, it offers dependable performance for both residential and commercial use. Enhanced with features such as firewall protection, NAT support, and VPN capabilities, the DWM-314-G is designed for secure networking. Managed remotely through various protocols, including SSH and OpenVPN, it supports easy configuration and monitoring. The modem also includes practical functionalities like port forwarding, MAC address authentication, and a built-in DHCP server, making it an ideal choice for advanced users seeking reliable and efficient networking solutions.
- D-Link DWM-314-G - wireless cellular modem - 5G LTE
- Wireless cellular modem
- Form Factor
- External
- Localisation
- Europe
- Max Transfer Rate
- 3.4 Gbps
- Mobile Communication Protocol
- 5G NR, 4G LTE, LTE Advanced Cat 18, LTE Advanced Cat 19
- Mobile Band
- 5G NR n1/n3/n5/n7/n8/n20/n28/n38/n40/n41/n71/n75/n76/n77/n78 4G LTE-FDD: B1/B3/B5/B7/B8/B20/B28/B32/B71 4G LTE-TDD: B38/B40/B41/B42/B43
- Power
- DC 9 - 36 V
- 13.1 cm x 9.9 cm x 4 cm
- Form Factor
- External
- Localisation
- Europe
Modem
- Connectivity Technology
- Wireless
- Max Transfer Rate
- 3.4 Gbps
- Mobile Band
- Antenna
- External detachable
- Antenna Qty
- 4
- DHCP, OpenVPN, WireGuard, NTP
- Remote Management Protocol
- ICMP, DHCP, DDNS, IPv4, IPv6, SSH
- NAT support, DHCP server, port forwarding, virtual server support, No-IP DDNS, VPN support, firewall protection, Intrusion Prevention System (IPS), Access Control List (ACL) support, MAC address authentication, firmware upgradable, event management, bridge mode, schedule reboot, machine-to-machine (M2M), manageable, corrosion-resistant, zinc-plated steel case, LED status indicator
- 4 x 1000Base-T - RJ-45 , 4 x aerial - SMA
- SIM Card Supported
- Micro-SIM x 2
- Cables Included
- 1 x network cable
- Included Accessories
- Power adapter, 4 cellular antennas, DIN rail mounting kit
- Plug and Play, UKCA
- Voltage Required
- DC 9 - 36 V
- 13.1 cm
- 9.9 cm
- 4 cm
- -30 °C
- 70 °C
- 10 - 95% (non-condensing)
