D-Link 5G/LTE Outdoor CPE
Quicklinx: J7JDWS00 Mfr#: DWP-1010/ODU/B
Hurry, only 1 left in stock!
£236.73 ex VAT
£284.07 inc VAT
Deploy this easy-to-install, high performance 5G/LTE outdoor CPE device. Equipped with a rugged IP67 weather-resistant housing, and flexible deployment options, it's ideal for both large-scale and individual deployments.
  • High-speed 5G Internet with dual-mode
    Connect with next-generation 5G speeds of up to 4 Gbps and experience lightning-fast downloads, lower latency and reduced congestion. It features x6 built-in powerful 5G/LTE D-Link antennas, and the DWP-1010 also supports fallback from 5G to LTE so you'll always be connected.
  • Withstands the weather
    Built with a rugged IP67 weather-resistant housing to help protect the DWP-1010 from extreme weather and provide clear reception, so you can continue to receive the best connectivity possible - come rain or shine.
  • Simple installation with Power over Ethernet (PoE)
    Comes with a 2.5 Gbps Ethernet LAN port with support for PoE, allowing a single Ethernet cable to carry both data and power to a device. No need to run extra power lines, no added hassle when configuring your hardwiring, and no more cable clutter.
D-Link DWP 1010 - wireless cellular modem - 5G LTE
Wireless cellular modem
External
Belgium
Mobile Communication Protocol
LTE, 5G
Mobile Band
5G n1/n3/n20/n28/n77/n78 LTE B1/B3/B7/B8/B20/B28/B38
IEEE 802.3i, IEEE 802.3u, IEEE 802.3at - 3.4 Gbps
48 V
10.54 cm x 14.48 cm x 21.04 cm
760 g
External
Belgium
Modem
Wireless
Qualcomm SDX55
Mobile Band
LTE, 5G
Antenna
Internal
Antenna Qty
6
Wireless
Data Transfer Rate
3.4 Gbps
1KV surge protection, 4KV ESD Protector (contact discharge), LED status indicator, reset button, PoE powered, outdoor
1 x 2.5GBase-T - RJ-45
SIM Card Supported
Micro-SIM x 1
IP67, Plug and Play
48 V
10.54 cm
14.48 cm
21.04 cm
760 g
-30 °C
50 °C
10 - 95% (non-condensing)
Brand: D-Link
