The DPS-700 redundant power supply (RPS) is designed to conform to the wattage requirements of D-Link's Ethernet and Gigabit switches. It is external RPS units enclosed in solid metal cases with sockets to AC or DC power sources on one end, and connect to a switch's internal power supply on the other end. It provides a low-cost, simple solution to the problem of an inadvertent failure of the internal power-supply of an Ethernet switch, which can result in the shutdown of that switch, the devices attached to its ports, or an entire network. Supporting full output power for the switch, these redundant power supplies can maximize the power availability of the switching device.
Redundant power backup
Each D-Link RPS is equipped with an integrated detection circuit that continuously monitors the switch's internal power supply. In the event of a power interruption, the redundant power supply is immediately triggered so that the LAN switch and its connected devices can continue providing service. -
Easy and flexible deployment
Deployment of a DPS series device does not require any change in the configuration of the LAN switch.
- D-Link DPS-700 - power supply - redundant - 589 watt
- Power supply - redundant - rack-mountable
- Rack Size
- 1U
- 3.7 kg
- Input Voltage
- AC 90-264 V
- Power Capacity
- 589 watt
- 19.5 cm x 19.6 cm x 5 cm
- Designed For
- xStack DGS-3120-24PC, DGS-3120-48PC
- Height (Rack Units)
- 1U
- Input Voltage
- AC 90-264 V
- Frequency Required
- 47 - 63 Hz
- Power Capacity
- 589 watt
- Efficiency
- 80%
- Cables Included
- Power cable - external - 1 m
- MTBF
- 624,961 hours
- LED indicators, 1+1 PoE Budget
- FCC Class B certified, UL, cUL, EN 60950, UL 60950 Third Edition, CSA C22.2
- 0 °C
- 65 °C
- 19.5 cm
- 19.6 cm
- 5 cm
- 3.7 kg
- Designed For
- D-Link xStack DGS-3120-24PC, DGS-3120-48PC
