D-Link 589W Redundant Power Supply
Quicklinx: 9TSYWS00 Mfr#: DPS-700
£900.59 ex VAT
£1,080.70 inc VAT
The DPS-700 redundant power supply (RPS) is designed to conform to the wattage requirements of D-Link's Ethernet and Gigabit switches. It is external RPS units enclosed in solid metal cases with sockets to AC or DC power sources on one end, and connect to a switch's internal power supply on the other end. It provides a low-cost, simple solution to the problem of an inadvertent failure of the internal power-supply of an Ethernet switch, which can result in the shutdown of that switch, the devices attached to its ports, or an entire network. Supporting full output power for the switch, these redundant power supplies can maximize the power availability of the switching device.
  • Redundant power backup
    Each D-Link RPS is equipped with an integrated detection circuit that continuously monitors the switch's internal power supply. In the event of a power interruption, the redundant power supply is immediately triggered so that the LAN switch and its connected devices can continue providing service.
  • Easy and flexible deployment
    Deployment of a DPS series device does not require any change in the configuration of the LAN switch.
D-Link DPS-700 - power supply - redundant - 589 Watt
Power supply - redundant - rack-mountable
Rack Size
1U
3.7 kg
Input Voltage
AC 90-264 V
Power Capacity
589 Watt
19.5 cm x 19.6 cm x 5 cm
xStack DGS-3120-24PC, DGS-3120-48PC
Height (Rack Units)
1U
Input Voltage
AC 90-264 V
Frequency Required
47 - 63 Hz
Power Capacity
589 Watt
Efficiency
80%
Power cable - external - 1 m
MTBF
624,961 hours
LED indicators, 1+1 PoE Budget
FCC Class B certified, UL, cUL, EN 60950, UL 60950 Third Edition, CSA C22.2
65 °C
19.5 cm
19.6 cm
5 cm
3.7 kg
D-Link xStack DGS-3120-24PC, DGS-3120-48PC
Type: Power Supplies
Brand: D-Link
Price Range Ex VAT: £750 - £1000
