The D-Link DGS 1530-52 is a versatile and robust rack-mountable switch designed for efficient networking in various environments. With a capacity for 48 ports operating at 10/100/1000 Mbps and 4 additional 10 Gigabit SFP+ ports, it ensures high-speed connections for demanding applications. The switch supports extensive VLAN functionality, allowing for efficient network segmentation and management across 255 VLAN groups. Additionally, it features a packet buffer size of 1.5 MB, providing the capability to handle heavy data traffic seamlessly. Operating in a wide temperature range from -5°C to 50°C and humidity levels up to 95% (non-condensing), this switch is built to withstand challenging conditions. It is compliant with multiple standards including IEEE 802.3 and has a proven MTBF of over 330,000 hours, indicating reliability. With features such as IGMP snooping, Quality of Service (QoS), and Energy-Efficient Ethernet, the D-Link DGS 1530-52 offers enhanced network performance, security, and efficiency.
Robust performance
With a switching capacity of 80 Gbps and forwarding performance of 176 Gbps, this switch effectively handles a high volume of network traffic. -
Flexible management
Supports various remote management protocols such as SNMP and RMON, ensuring easy network management and monitoring. -
Enhanced security
Equipped with advanced security features including RADIUS and TACACS+ authentication, ensuring secure access to the network. -
Energy efficiency
Features Energy-Efficient Ethernet (EEE) technology to reduce power consumption while maintaining performance. -
High compatibility
Compliant with numerous standards including IEEE 802.3ab and 802.1AX, ensuring compatibility with a wide range of network devices.
- D-Link DGS 1530-52 - switch - 48 ports - smart - rack-mountable
- Switch - 48 ports - smart - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 + 4 x 10 Gigabit SFP+
- Performance
- Switching capacity: 176 Gbps , Forwarding performance (64-byte packet size): 130.95 Mpps , Stacking bandwidth: 80 Gbps
- Capacity
- Packet buffer size: 1.5 MB , MLD groups: 1024 , VLAN groups: 4094 , Static ARP entries: 255
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 10240 bytes
- Routing Protocol
- IGMP, IGMPv2, IGMPv3, MLD, MLDv2, static IP routing
- Remote Management Protocol
- SNMP 1, SNMP 2c, SNMP 3, RMON 1, RMON 2
- ERPS, MDI, MDI-X, Link Aggregation, STP support, BPDU Filter, Loop Guard, MSTP support, RSTP, Root Guard, flow mirroring, loopback detection, port mirroring, IGMP snooping, GVRP, Private VLAN, VLAN trunking, Voice VLAN, QoS, WDRR, WRED, WRR, CoS, BPDU, DoS, EEE, D-Link DDP, NTP 3, NTP 4, LACP support, store and forward, auto-uplink (auto MDI/MDI-X), half/full duplex mode, 2 fans, 6KV Surge protection
- IEEE 802.11d, IEEE 802.11p, IEEE 802.11q, IEEE 802.11s, IEEE 802.11v, IEEE 802.11w, IEEE 802.1AX, IEEE 802.3ab, IEEE 802.3ae, IEEE 802.3az, IEEE 802.3u, IEEE 802.3x, IEEE 802.3z
- Power
- AC 100-240 V (50/60 Hz)
- 44 cm x 21 cm x 4.4 cm
- 3.2 kg
- Localisation
- United Kingdom
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 16K entries
- 10240 bytes
- Max Units In A Stack
- 9
- Routing Protocol
- Encryption Algorithm
- TLS 1.2
- Authentication Method
- Secure Shell v.2 (SSH2), RADIUS, TACACS+
- Status Indicators
- Console, link/activity/speed, power, RPS (Redundant Power Supply)
- 48 x 1000Base-T RJ-45 , 4 x 1000Base-X SFP+ , 1 x management RJ-45 , 1 x USB 2.0 Type A
- Power Device
- Internal power supply
- Voltage Required
- Rack Mounting Kit
- Included
- MTBF
- 330,520 hours
- BSMI, CB, cUL, EMC, FCC, IC, LVD, RCM, UKCA, VCCI
- Localisation
- United Kingdom
- 44 cm
- 21 cm
- 4.4 cm
- 3.2 kg
- -5 °C
- 50 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- 20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
