D-Link 52-Port Gigabit Stackable Smart Managed Switch with 4 x 10G SFP+ Ports
Quicklinx: J7KVWS00 Mfr#: DGS-1530-52/B
Type: Gigabit Ethernet
Ports: 48
Managed: Yes
£798.70 ex VAT
£958.44 inc VAT
The D-Link DGS 1530-52 is a versatile and robust rack-mountable switch designed for efficient networking in various environments. With a capacity for 48 ports operating at 10/100/1000 Mbps and 4 additional 10 Gigabit SFP+ ports, it ensures high-speed connections for demanding applications. The switch supports extensive VLAN functionality, allowing for efficient network segmentation and management across 255 VLAN groups. Additionally, it features a packet buffer size of 1.5 MB, providing the capability to handle heavy data traffic seamlessly. Operating in a wide temperature range from -5°C to 50°C and humidity levels up to 95% (non-condensing), this switch is built to withstand challenging conditions. It is compliant with multiple standards including IEEE 802.3 and has a proven MTBF of over 330,000 hours, indicating reliability. With features such as IGMP snooping, Quality of Service (QoS), and Energy-Efficient Ethernet, the D-Link DGS 1530-52 offers enhanced network performance, security, and efficiency.
  • Robust performance
    With a switching capacity of 80 Gbps and forwarding performance of 176 Gbps, this switch effectively handles a high volume of network traffic.
  • Flexible management
    Supports various remote management protocols such as SNMP and RMON, ensuring easy network management and monitoring.
  • Enhanced security
    Equipped with advanced security features including RADIUS and TACACS+ authentication, ensuring secure access to the network.
  • Energy efficiency
    Features Energy-Efficient Ethernet (EEE) technology to reduce power consumption while maintaining performance.
  • High compatibility
    Compliant with numerous standards including IEEE 802.3ab and 802.1AX, ensuring compatibility with a wide range of network devices.
D-Link DGS 1530-52 - switch - 48 ports - smart - rack-mountable
Switch - 48 ports - smart - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x 10 Gigabit SFP+
Performance
Switching capacity: 176 Gbps , Forwarding performance (64-byte packet size): 130.95 Mpps , Stacking bandwidth: 80 Gbps
Packet buffer size: 1.5 MB , MLD groups: 1024 , VLAN groups: 4094 , Static ARP entries: 255
MAC Address Table Size
16K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
IGMP, IGMPv2, IGMPv3, MLD, MLDv2, static IP routing
Remote Management Protocol
SNMP 1, SNMP 2c, SNMP 3, RMON 1, RMON 2
ERPS, MDI, MDI-X, Link Aggregation, STP support, BPDU Filter, Loop Guard, MSTP support, RSTP, Root Guard, flow mirroring, loopback detection, port mirroring, IGMP snooping, GVRP, Private VLAN, VLAN trunking, Voice VLAN, QoS, WDRR, WRED, WRR, CoS, BPDU, DoS, EEE, D-Link DDP, NTP 3, NTP 4, LACP support, store and forward, auto-uplink (auto MDI/MDI-X), half/full duplex mode, 2 fans, 6KV Surge protection
IEEE 802.11d, IEEE 802.11p, IEEE 802.11q, IEEE 802.11s, IEEE 802.11v, IEEE 802.11w, IEEE 802.1AX, IEEE 802.3ab, IEEE 802.3ae, IEEE 802.3az, IEEE 802.3u, IEEE 802.3x, IEEE 802.3z
AC 100-240 V (50/60 Hz)
44 cm x 21 cm x 4.4 cm
3.2 kg
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
10240 bytes
Max Units In A Stack
9
Routing Protocol
Encryption Algorithm
TLS 1.2
Authentication Method
Secure Shell v.2 (SSH2), RADIUS, TACACS+
Status Indicators
Console, link/activity/speed, power, RPS (Redundant Power Supply)
48 x 1000Base-T RJ-45 , 4 x 1000Base-X SFP+ , 1 x management RJ-45 , 1 x USB 2.0 Type A
Internal power supply
Rack Mounting Kit
Included
MTBF
330,520 hours
BSMI, CB, cUL, EMC, FCC, IC, LVD, RCM, UKCA, VCCI
United Kingdom
44 cm
21 cm
4.4 cm
3.2 kg
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 48
Managed: Yes
Brand: D-Link
Price Range Ex VAT: £750 - £1000
