D-Link 52-Port Gigabit Stackable PoE+ Smart Managed  Switch with 4 x 10G SFP+ Ports
Quicklinx: J7KWWS00 Mfr#: DGS-1530-52P/B
Type: Gigabit Ethernet
Ports: 48
Managed: Yes
POE: PoE+
£1,410.12 ex VAT
£1,692.14 inc VAT
The D-Link DGS-1530-52P is a managed switch designed to enhance network performance and versatility. With a switching capacity of up to 80 Gbps and a forwarding performance of 130.95 Mpps, this model ensures efficient data handling in various network environments. The device's 48 ports of 10/100/1000 Base-T (PoE+) support a substantial PoE budget of 370 W, allowing for seamless power delivery to connected devices. Engineered for performance, the DGS-1530-52P supports features like IGMP snooping, Quality of Service (QoS), and various redundancy protocols, promoting reliability and optimized data flow. Its stackable design enables the connection of up to 9 units, offering scalability to suit growing demands. The compact rack-mountable form factor makes it practical for mounting in data centers or network closets, while the built-in environmental resilience ensures optimal functionality across a wide range of temperatures and humidity levels.
  • Switching capacity
    With a switching capacity of 80 Gbps, this switch handles a large volume of data traffic efficiently.
  • PoE capabilities
    Equipped with a 370 W PoE budget, this device supports power-hungry devices like IP cameras and wireless access points.
  • Management options
    Supports multiple remote management protocols such as SNMP and RMON for efficient network administration.
  • Scalable design
    Stackable configuration allows connection of up to 9 switches for increased capacity and simplified management.
  • Environmental durability
    Operational in a broad temperature range of -5°C to 50°C, ensuring reliability in diverse environments.
D-Link DGS 1530-52P - switch - 48 ports - smart - rack-mountable
Switch - 48 ports - smart - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (1 PoE+) + 4 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
370 W
Performance
Switching capacity: 176 Gbps , Forwarding performance (64-byte packet size): 130.95 Mpps , Stacking bandwidth: 80 Gbps
Packet buffer size: 1.5 MB , MLD groups: 1024 , VLAN groups: 4094 , Static ARP entries: 255
MAC Address Table Size
16K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
IGMP, IGMPv2, IGMPv3, MLD, MLDv2, static IP routing
Remote Management Protocol
SNMP 1, SNMP 2c, SNMP 3, RMON 1, RMON 2
ERPS, MDI, MDI-X, Link Aggregation, STP support, BPDU Filter, Loop Guard, MSTP support, RSTP, Root Guard, flow mirroring, loopback detection, port mirroring, IGMP snooping, GVRP, Private VLAN, VLAN trunking, Voice VLAN, QoS, WDRR, WRED, WRR, CoS, BPDU, DoS, EEE, D-Link DDP, NTP 3, NTP 4, LACP support, store and forward, auto-uplink (auto MDI/MDI-X), half/full duplex mode, 3 fans, 6KV Surge protection
IEEE 802.11d, IEEE 802.11p, IEEE 802.11q, IEEE 802.11s, IEEE 802.11v, IEEE 802.11w, IEEE 802.1AX, IEEE 802.3ab, IEEE 802.3ae, IEEE 802.3az, IEEE 802.3u, IEEE 802.3x, IEEE 802.3z, IEEE 802.3af, IEEE 802.3at
AC 100-240 V (50/60 Hz)
44 cm x 30.8 cm x 4.4 cm
4.35 kg
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
370 W
Performance
16K entries
Jumbo Frame Support
10240 bytes
Max Units In A Stack
9
Routing Protocol
Encryption Algorithm
TLS 1.2
Authentication Method
Secure Shell v.2 (SSH2), RADIUS, TACACS+
Status Indicators
Console, link/activity/speed, power, RPS (Redundant Power Supply)
48 x 10/100/1000 Base-T (PoE+) RJ-45 30 W , 4 x 1000Base-X SFP+ , 1 x management RJ-45 , 1 x USB 2.0 Type A
Internal power supply
Rack Mounting Kit
Included
MTBF
230,300 hours
BSMI, CB, cUL, EMC, FCC, IC, LVD, RCM, UKCA, VCCI, IEEE 802.3af, IEEE 802.3at
United Kingdom
44 cm
30.8 cm
4.4 cm
4.35 kg
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 48
Managed: Yes
POE: PoE+
Brand: D-Link
Price Range Ex VAT: £1000 - £1500
