The D-Link DGS-1530-52P is a managed switch designed to enhance network performance and versatility. With a switching capacity of up to 80 Gbps and a forwarding performance of 130.95 Mpps, this model ensures efficient data handling in various network environments. The device's 48 ports of 10/100/1000 Base-T (PoE+) support a substantial PoE budget of 370 W, allowing for seamless power delivery to connected devices. Engineered for performance, the DGS-1530-52P supports features like IGMP snooping, Quality of Service (QoS), and various redundancy protocols, promoting reliability and optimized data flow. Its stackable design enables the connection of up to 9 units, offering scalability to suit growing demands. The compact rack-mountable form factor makes it practical for mounting in data centers or network closets, while the built-in environmental resilience ensures optimal functionality across a wide range of temperatures and humidity levels.
Switching capacity
With a switching capacity of 80 Gbps, this switch handles a large volume of data traffic efficiently. -
PoE capabilities
Equipped with a 370 W PoE budget, this device supports power-hungry devices like IP cameras and wireless access points. -
Management options
Supports multiple remote management protocols such as SNMP and RMON for efficient network administration. -
Scalable design
Stackable configuration allows connection of up to 9 switches for increased capacity and simplified management. -
Environmental durability
Operational in a broad temperature range of -5°C to 50°C, ensuring reliability in diverse environments.
- D-Link DGS 1530-52P - switch - 48 ports - smart - rack-mountable
- Switch - 48 ports - smart - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 (1 PoE+) + 4 x 10 Gigabit SFP+
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 370 W
- Performance
- Switching capacity: 176 Gbps , Forwarding performance (64-byte packet size): 130.95 Mpps , Stacking bandwidth: 80 Gbps
- Capacity
- Packet buffer size: 1.5 MB , MLD groups: 1024 , VLAN groups: 4094 , Static ARP entries: 255
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 10240 bytes
- Routing Protocol
- IGMP, IGMPv2, IGMPv3, MLD, MLDv2, static IP routing
- Remote Management Protocol
- SNMP 1, SNMP 2c, SNMP 3, RMON 1, RMON 2
- ERPS, MDI, MDI-X, Link Aggregation, STP support, BPDU Filter, Loop Guard, MSTP support, RSTP, Root Guard, flow mirroring, loopback detection, port mirroring, IGMP snooping, GVRP, Private VLAN, VLAN trunking, Voice VLAN, QoS, WDRR, WRED, WRR, CoS, BPDU, DoS, EEE, D-Link DDP, NTP 3, NTP 4, LACP support, store and forward, auto-uplink (auto MDI/MDI-X), half/full duplex mode, 3 fans, 6KV Surge protection
- IEEE 802.11d, IEEE 802.11p, IEEE 802.11q, IEEE 802.11s, IEEE 802.11v, IEEE 802.11w, IEEE 802.1AX, IEEE 802.3ab, IEEE 802.3ae, IEEE 802.3az, IEEE 802.3u, IEEE 802.3x, IEEE 802.3z, IEEE 802.3af, IEEE 802.3at
- Power
- AC 100-240 V (50/60 Hz)
- 44 cm x 30.8 cm x 4.4 cm
- 4.35 kg
- Localisation
- United Kingdom
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 370 W
- Performance
- Capacity
- 16K entries
- 10240 bytes
- Max Units In A Stack
- 9
- Routing Protocol
- Encryption Algorithm
- TLS 1.2
- Authentication Method
- Secure Shell v.2 (SSH2), RADIUS, TACACS+
- Status Indicators
- Console, link/activity/speed, power, RPS (Redundant Power Supply)
- 48 x 10/100/1000 Base-T (PoE+) RJ-45 30 W , 4 x 1000Base-X SFP+ , 1 x management RJ-45 , 1 x USB 2.0 Type A
- Power Device
- Internal power supply
- Voltage Required
- Rack Mounting Kit
- Included
- MTBF
- 230,300 hours
- BSMI, CB, cUL, EMC, FCC, IC, LVD, RCM, UKCA, VCCI, IEEE 802.3af, IEEE 802.3at
- Localisation
- United Kingdom
- 44 cm
- 30.8 cm
- 4.4 cm
- 4.35 kg
- -5 °C
- 50 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
