D-Link 5 Port Unmanaged Switch with 5 x 10/100 BaseT(X) ports
Quicklinx: J7MDWS00 Mfr#: DIS-100E-5W
Type: Fast Ethernet
Ports: 5
Managed: No
£121.66 ex VAT
£145.99 inc VAT
The DIS-100E Series Industrial Fast Ethernet Unmanaged Switches are designed specifically to withstand wide temperature range, vibrations and shock. These rugged, yet easy to deploy, switches have superior environmental specification compared to those of commercial network switches. With its hardened design combined with high availability network features, these switches form vital parts of any network infrastructure facilitating the increasing demand for smart cities, city-wide surveillance and wireless connectivity. DIS-100E Series Unmanaged Switches provides 5 and 8 Fast Ethernet ports and are designed for supporting standard industrial applications without complex setup to make the network truly plug-and-play.
  • Rugged, hardened design
    Design to operate in wide temperature ranges, vibration, shock, allowing the switches to be deployed in enclosures or cabinets in outdoor locations.
  • Easily installation
    Simple plug & play installation with DIN-rail mounting ability.
  • Redundant power input with alarm
    Redundant power input ensure network uptime should a power supply fail, whilst power alarm relay output notifies you instantly when a power supply has failed.
D-Link DIS 100E-5W - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Fast Ethernet
Ports
5 x 10/100
MAC Address Table Size
1K entries
Store and forward, non blocking ports, wire speed forwarding, full duplex mode, half duplex mode, broadcast storm protection, MDI/MDI-X switch
IEEE 802.3x
DC 12 - 58 V
10.92 cm x 2.91 cm x 8.94 cm
320 g
Enclosure Type
DIN rail mountable, wall-mountable
Subtype
Fast Ethernet
Ports
5 x 10/100
1K entries
IEEE 802.3x
Status Indicators
Power, status, link/speed
5 x 100Base-TX RJ-45
DC 12 - 58 V
1.56 watt
Power Consumption Stand by
0.95 watt
MTBF
25 years
Plug and Play, IEC 60068-2-6, IEC 60068-2-27, IEC 60068-2-32, FCC Part 15, EN 61000-6-2, IEC 61000-6-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-4, EN 61000-4-5, EN 61000-4-6, UL 60950-1, RoHS, FCC, WEEE, IP30, CSA C22
10.92 cm
2.91 cm
8.94 cm
320 g
-40 °C
75 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Humidity Range Storage
Type: Fast Ethernet
Ports: 5
Managed: No
Brand: D-Link
