D-Link 5 Port Unmanaged Switch 4 x 10/100/1000BaseT(X) ports (4 PoE) & 1 x 100/1000BaseSFP ports
Quicklinx: J7MKWS00 Mfr#: DIS-100G-5PSW
Hurry, only 1 left in stock!
£165.19 ex VAT
£198.22 inc VAT
The DIS-100G series industrial Gigabit unmanaged switches are designed specifically to withstand wide temperature range, vibrations and shock. These rugged, yet easy to deploy, switches have superior environmental specification compared to those of commercial network switches. With hardened design combined with high availability network features, these switches form vital parts of any network infrastructure facilitating the increasing demand for
smart cities, city-wide surveillance and wireless connectivity.
  • Rugged, hardened design
    It's designed to operate in wide temperature ranges, vibration, shock, allowing the switches to be deployed in enclosures or cabinets in outdoor locations.
  • Easily installation
    Enjoy a simple plug & play installation with DIN-rail mounting ability.
D-Link DIS 100G-5PSW - switch - 4 ports - unmanaged
Switch - 4 ports - unmanaged
Ports
4 x 10/100/1000 (PoE+) + 1 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
120 W
MAC Address Table Size
2K entries
Jumbo Frame Support
9KB
Auto-negotiation, store and forward, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, QoS, fanless, rugged, Back Pressure Support, reverse polarity protection, dual power input
IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
DC 12 - 58 V
13.9 cm x 2.9 cm x 10.7 cm
375 g
5-year warranty
Enclosure Type
DIN rail mountable, wall-mountable
Ports
PoE+
PoE Budget
120 W
2K entries
Jumbo Frame Support
9KB
Status Indicators
Power, PoE, link/speed
4 x 1000Base-T RJ-45 PoE+ - 30 W , 1 x 1000Base-X SFP
Internal power supply
DC 12 - 58 V
120.2 Watt
Overload Current Protection
Snap-to-DIN-rail clip
MTBF
25 years
Plug and Play, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EN 61000-4-5, FCC, EN 61000-6-2, RoHS, EN 61000-6-4, WEEE, IEC 60068-2-27, IEC 60068-2-32, IEC 60068-2-6, UL 61010-1, IP30
13.9 cm
2.9 cm
10.7 cm
375 g
Limited warranty - 5 years
-40 °C
75 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Humidity Range Storage
Brand: D-Link
