The DIS-100G series industrial Gigabit unmanaged switches are designed specifically to withstand wide temperature range, vibrations and shock. These rugged, yet easy to deploy, switches have superior environmental specification compared to those of commercial network switches. With hardened design combined with high availability network features, these switches form vital parts of any network infrastructure facilitating the increasing demand for
smart cities, city-wide surveillance and wireless connectivity.
Rugged, hardened design
It's designed to operate in wide temperature ranges, vibration, shock, allowing the switches to be deployed in enclosures or cabinets in outdoor locations. -
Easily installation
Enjoy a simple plug & play installation with DIN-rail mounting ability.
- D-Link DIS 100G-5PSW - switch - 4 ports - unmanaged
- Switch - 4 ports - unmanaged
- Ports
- 4 x 10/100/1000 (PoE+) + 1 x Gigabit SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 120 W
- MAC Address Table Size
- 2K entries
- Jumbo Frame Support
- 9KB
- Auto-negotiation, store and forward, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, QoS, fanless, rugged, Back Pressure Support, reverse polarity protection, dual power input
- IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
- Power
- DC 12 - 58 V
- 13.9 cm x 2.9 cm x 10.7 cm
- 375 g
- 5-year warranty
- Enclosure Type
- DIN rail mountable, wall-mountable
- Ports
- PoE+
- PoE Budget
- 120 W
- 2K entries
- 9KB
- Status Indicators
- Power, PoE, link/speed
- 4 x 1000Base-T RJ-45 PoE+ - 30 W , 1 x 1000Base-X SFP
- Power Device
- Internal power supply
- Voltage Required
- DC 12 - 58 V
- 120.2 Watt
- Overload Current Protection
- Included Accessories
- Snap-to-DIN-rail clip
- MTBF
- 25 years
- Plug and Play, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EN 61000-4-5, FCC, EN 61000-6-2, RoHS, EN 61000-6-4, WEEE, IEC 60068-2-27, IEC 60068-2-32, IEC 60068-2-6, UL 61010-1, IP30
- 13.9 cm
- 2.9 cm
- 10.7 cm
- 375 g
- Limited warranty - 5 years
- -40 °C
- 75 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 85 °C
- Humidity Range Storage
