D-Link 5-Port Gigabit Ethernet Metal Housing Unmanaged Switch
Quicklinx: J7LJWS00 Mfr#: DGS-105GL/B
14 In Stock
£13.48 ex VAT
£16.17 inc VAT
The DGS-105GL boasts peak value for home offices or SMBs in enabling easy and rapid network expansions, upgrading connections with a hassle-free plug and play switch solution.
  • Ready to serve for years to come
    The DGS-105GL features a fanless design for silent operation, reduced energy consumption, and enhanced reliability by eliminating a common point of failure for an extended product life.
  • Prioritize what's important with quality of service
    Quality of Service (QoS) support enhances your network's efficiency. QoS cleverly prioritizes network traffic so that time-sensitive data - such as VoIP or data to and from your NAS - is unaffected even during bursts of high-volume traffic. This allows for an all-round smoother, uninterrupted network experience.
  • Setup that doesn't dent your productivity
    Expanding your network shouldn't take a whole morning of navigating complex setup software. Simply place the DGS-105GL on a desktop or conveniently wall mount, connect it to your network via Ethernet cables and you're set.
D-Link DGS 105GL - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
Switching capacity: 10 Gbps , Packet filter/forwarding rate (10 Mbps): 14880 pps , Packet filter/forwarding rate (100 Mbps): 148800 pps , Packet filter/forwarding rate (1000 Mbps):: 1488000 pps
MAC Address Table Size
2K entries
Flow control, auto-uplink (auto MDI/MDI-X), store and forward, QoS, D-Link Green Technology, fanless, metal housing, VoIP support, NAS support, SOHO, EEE
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
10 cm x 6.7 cm x 2.4 cm
160 g
United Kingdom
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
2K entries
Status Indicators
Power, link/activity
5 x 1000Base-T RJ-45
External power adapter
Power Provided
DC 5 V - 1 A
3.55 Watt
MTBF
1,455,562 hours
Plug and Play, FCC, RoHS
United Kingdom
10 cm
6.7 cm
2.4 cm
160 g
10 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
Brand: D-Link
