D-Link's DGS-1100 Series provides an affordable solution for SOHOs and Small and Medium Businesses as well as enterprise deployment, such as in branch offices and meeting rooms that require simple network management. Enhanced management features, diagnostic and troubleshooting tools, and energy efficient technologies provide a flexible solution to suit your networking requirements.
Efficient power management
The D-Link Smart Managed Switch is designed with PoE (Power over Ethernet) capabilities, allowing for efficient power management and device flexibility. With a PoE budget of 18 W when using 802.3at input power and 8 W with 802.3af input power, it ensures that connected devices are adequately powered, reducing the need for additional power sources. -
Robust performance
Boasting a switching capacity of 10 Gbps and a forwarding performance rate of 7.4 Mpps, this switch is engineered to handle high volumes of data with ease. Its capacity to support up to 32 VLAN groups, 32 IGMP groups, and 2000 MAC address entries makes it a versatile choice for managing complex network configurations. -
Advanced networking features
Equipped with features like Quality of Service (QoS), bandwidth control, and IGMP snooping, the DGS-1100-05PD enhances network efficiency and traffic prioritization. Its support for jumbo frames up to 9216 bytes and fanless design for silent operation further complement its advanced networking capabilities.
- D-Link Smart Managed Switch DGS-1100-05PD - switch - 5 ports - smart
- Switch - 5 ports - smart
- Subtype
- Gigabit Ethernet
- Ports
- 2 x 10/100/1000 (PoE) + 3 x 10/100/1000
- Power Over Ethernet (PoE)
- PoE
- Performance
- Switching capacity: 10 Gbps , Forwarding performance: 7.4 Mpps
- Capacity
- VLAN groups: 32 , IGMP groups: 32 , Queues per port: 4 , MAC address entries: 32
- MAC Address Table Size
- 2000 entries
- Jumbo Frame Support
- 9216 bytes
- Flow control, BOOTP support, IGMP snooping, port mirroring, QoS, Cable Diagnostics Function, bandwidth control, IPv4 support, fanless, DHCP client, tagged VLAN, PoE Budget: 18 W (802.3at input power) / 8 W (802.3af input power)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3q
- 15 cm x 9.7 cm x 2.8 cm
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- Performance
- Capacity
- 2000 entries
- 9216 bytes
- Flash Memory
- 2 MB
- 2 x Gigabit LAN RJ-45 PoE - 15.4 W , 2 x Gigabit LAN RJ-45 , 1 x Gigabit LAN RJ-45 PoE input
- Power Device
- Power injector
- PoE powered
- 15 cm
- 9.7 cm
- 2.8 cm
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
