D-Link 5 Port 10/100/1000 Green Ethernet Gigabit Desktop Switch
TOP QUALITY GIGABIT SWITCH - WAS £17.48!
Customer rating: 5.0* (Write a review)
Quicklinx: 2VFRWS00 Mfr#: DGS-1005D/B
Type: Gigabit Ethernet
Ports: 5
Data Transfer Rate: 1Gbps
Managed: No
POE: No
Hurry, only 3 left in stock!
£9.26 ex VAT
£11.11 inc VAT
This desktop switch offers an inexpensive alternative to fibre optics for the SOHO and small and medium business (SMB). Increasing network loads can be handled with the increased bandwidth of Gigabit Ethernet.
Gigabit connectivity without fibre
The switch provides 5 Gigabit ports in the familiar Ethernet format, so it works seamlessly with existing network cables (CAT5 or higher). Up to 2000 Mbps can be achieved in full-duplex mode, giving workstations bottleneck-free access to server data.
Plug-and-Play installation
All there is to do is plug the cables into the switch. All ports support both straight-through and crossover cable types, eliminating the need for an uplink port. And with 10/100/1000 Mbps auto-sensing, no configuration is required.
Think Green
By sensing whether attached devices are ON or OFF and estimating the cable length, the switch is able to adjust its power consumption, for a total saving of up to 27%*.
*Figure based on a scenario assuming that PCs are used for 10 hours a day, powered off 14 hours a day and connected to the switch using 20m cables.
  • Power-saving feature, up to 27%* less power consumption (dlink green version only)
  • 5 Gigabit Ethernet ports
  • Plug-and-play installation
  • Desktop size, no fan
D-Link DGS 1005D - switch - 5 ports
Switch - 5 ports
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
MAC Address Table Size
8K entries
Flow control, full duplex capability, Layer 2 switching, auto-sensing per device, auto-negotiation, IGMP snooping, packet filtering
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x
9.4 cm x 7.5 cm x 2.245 cm
Switch - 5 ports
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
8K entries
RAM
256 KB
Status Indicators
Power, link/activity
5 x 1000Base-T RJ-45
Internal power supply
2.847 Watt
MTBF
1,479,725 hours
Plug and Play, FCC Class A certified, cUL, VCCI Class A ITE
9.4 cm
7.5 cm
2.245 cm
Shipping Width
9.9 cm
Shipping Depth
8.5 cm
Shipping Height
9.2 cm
55 °C
5 - 95%
2VFR C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
2VFR C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.75
2VFR C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.87
Resources
The following resources are available for the D-Link 5 Port 10/100/1000 Green Ethernet Gigabit Desktop Switch
Customer reviews
Write a review for the D-Link 5 Port 10/100/1000 Green Ethernet Gigabit Desktop Switch here!
Excellent choice
Reviewed by Ilias. Review Posted 24/11/2008
A really good and simple to use product. Price and warranty are fantastic as well (especially when compared to both home and business 5-port switches by Netgear). A highly recommended purchase!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Switch To D-Link
Reviewed by John Heaton. Review Posted 25/06/2007
Cheap, Fast & Compact. Add to this it does exactly what it says on the tin, and you have yourself a very good product indeed. Unmanaged means no messing about with silly web based settings. Auto MDI/MDI-X means no running to PC World and getting ripped off by Belkin for a cross-over adapter. 5 ports actually does mean 5 usable ports, as is, no 4 + 1 uplink. In the past I've avoided D-link as their products look like retro 80's junk. However out of the box it looks a lot nicer than you'd think, and those nasty go faster holes the switch has been dotted with actually come in handy for stacking. Ideal for any home user on a budget wanting to connect several network devices at high 1 Gbit speeds (with ease). No nonsense networking, it’s about time.
  • Overall 5*
  • Ease of use 5*
simply the best value for money
Reviewed by Anonymous Review Posted 26/09/2007
as unmanaged switches go, this is amazing value for money. it does exactly what is should: it is fast (yes it is!), it is simple to install (plug'n'go) and it is quite nice looking (well...). it also consumes very little power (max 9W) which is a good thing. gigabit for the masses!
  • Overall 5*
  • Ease of use 5*
Read all 4 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Ports: 5
Managed: No
POE: No
Brand: D-Link
