D-Link 4G LTE M2M VPN Modem Router
Quicklinx: J7J8WS00 Mfr#: DWM-313
15 In Stock
£97.15 ex VAT
£116.58 inc VAT
Easy-to-use, high-performance, industrial-grade 4G/3G mobile router for Machine-to-Machine applications in any environment.
  • Wired and wireless connectivity for broad compatibility
    The DWM-312W offers maximum flexibility for Machine-to-Machine applications with wireless and wired connectivity.
  • Dual-SIM slot for uninterrupted Internet connectivity
    Configurable dual-SIM fallback ensures reliable connectivity, even if an operator's network fails.
  • Easy Management
    Local and remote access via web / Telnet / SSH and SNMP support. TR-069 management platform and D-ECS available for projects.
  • Specially built for M2M environments
    Remotely monitor and manage your Machine-to-Machine networks with the DWM-313 industrial-grade device. Features such as redundant mobile Internet with dual-SIM slot, secure VPN connection, flexible wired and wireless LAN connectivity ensure uninterrupted operation of your M2M applications, 24/7.
  • Your Internet connectivity will no longer cause you problems
    It is possible that service interruptions may occur at any time, but Failover technology has been developed to eliminate them altogether.
  • Connectivity where you need it most
    Easily connect to your high-speed 4G/3G LTE mobile network and enjoy fast downlink and uplink speeds for fast, reliable and responsive Internet access that allows you to use your router in remote locations and access your devices wherever you are.
  • Reliable, secure and high-speed VPN
    The DWM-313 can support almost any VPN policy and handle multiple configurations. It even supports IPSec, GRE and OpenVPN protocols, as well as handling pass-through traffic. Advanced VPN configurations include various encryption options, Key Management, negotiation modes, and VPN authentication using an internal user database.
  • Easy installation in extreme conditions
    Corrosion-resistant galvanized steel housing and wide tolerance for operating temperature and humidity make the DWM-313 an industrial-grade device that adapts to even the most complicated M2M environments.
D-Link DWM-313 - wireless router - WWAN - Wi-Fi - 3G, 4G - wall-mountable
Wireless router - wireless cellular modem - 2-port switch (integrated)
Enclosure Type
Wall-mountable
Mobile Communication Protocol
LTE, UMTS, GSM, GPRS, EDGE, FDD LTE, TDD LTE, HSPA, HSUPA, DC-HSDPA, WCDMA
Generation
3G, 4G
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Network / Transport Protocol
IPSec, PPTP, L2TP, HTTP
Routing Protocol
GRE
Remote Management Protocol
SNMP, TR-069
NAT support, SPI, VPN support, OpenVPN client, M2M
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.3i, IEEE 802.3u
DC 5 -18 V
9.3 cm x 7 cm x 2.36 cm
210 g
Wireless router - 2-port switch (integrated)
Enclosure Type
Wall-mountable
Wired, wireless
Frequency Band
2.4 GHz
Routing Protocol
GRE
SNMP, TR-069
Encryption Algorithm
128-bit AES, 64-bit WEP, 128-bit WEP
Status Indicators
Status
Communications
Wireless cellular modem
Generation
3G, 4G
Max Transfer Rate
150 Mbps
WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB: 1 x RS-232
Expansion Slots
2 (total) / 2 (free) x Micro-SIM , 1 (total) / 1 (free) x microSD
Aerial
Aerial
External detachable
Antenna Qty
3
Configuration Details
2 detachable external LTE aerials, 1 detachable WiFi aerial
External power adapter
Installed Qty
1
DC 5 -18 V
9.3 cm
7 cm
2.36 cm
210 g
-30 °C
60 °C
10 - 90% (non-condensing)
Brand: D-Link
