D-Link 4G LTE M2M VPN Modem Router
Quicklinx: J7J4WS00 Mfr#: DWM-311
16 In Stock
£97.61 ex VAT
£117.13 inc VAT
D-Link's DWM-311 4G LTE M2M Modem is a robust 4G LTE modem that provides blazing fast connection speeds for embedded Machine-to-Machine (M2M) applications. The single mode LTE modem provides an economical and reliable high speed connection suitable for the most demanding Internet of Things (IoT) applications. This cost-effective device is pre-configured to provide a complete connectivity solution out of the box.
  • Robust
    The industrial grade casing means the DWM-311 provides reliable high-speed connectivity in extreme conditions. The corrosion-resistant zinc-plated steel case and wide operating temperature and humidity tolerance mean that the DWM-311 is ready for the most demanding M2M applications in virtually any environment. Wall mounts and flexible interfaces allow the DWM-311 to be mounted virtually anywhere for optimal connectivity.
  • Flexible
    The DWM-311's USB and Ethernet interfaces allow connectivity to be added to virtually any device. Ethernet means driverless, instant access for any Ethernet-enabled device, without the need for pre-configuration or special software. Standard USB protocols allow you to add highspeed Internet access to devices not traditionally equipped with network adapters. Ethernet makes the DWM-311 a true plug-and-play solution, suitable for mass deployment or small scale use. Should unique settings be required, the easy-to-use web interface can be configured through any web browser.
D-Link DWM-311 - wireless cellular modem - 4G LTE
Wireless cellular modem - USB 2.0 / Ethernet 100
External
Max Transfer Rate
150 Mbps
Mobile Communication Protocol
LTE
DC 5 V
10.7 cm x 4.8 cm x 1.9 cm
145 g
1-year warranty
External
Modem
Bus
Wireless
Max Transfer Rate
150 Mbps
LTE
Antenna
External detachable
Antenna Qty
2
Wall mountable
USB powered, Firmware Over-the-Air (FOTA), Adaptive Coding & Modulation (ACM)
IEEE 802.3u, IEEE 802.3i
1 x 100Base-TX - RJ-45 , 1 x micro-USB 2.0 , 2 x aerial - SMA , 1 x mini-USB
Service Provider
Verizon Wireless
Plug and Play, FCC
DC 5 V
Limited warranty - 1 year
10.7 cm
4.8 cm
1.9 cm
145 g
-20 °C
60 °C
5 - 85% (non-condensing)
Brand: D-Link
