The D-Link DWM-312 4G LTE M2M Router is an easy-to-deploy, high performance 3G/4G router. It features a dedicated Fast Ethernet port and dual-SIM 4G LTE mobile broadband for maximum redundancy and ?exibility for intense Machine to Machine applications. Powerful VPN tools and advanced remote management combined with ease of use make the DWM-312 ideal for both large-scale and individual deployments.
Easily connect to your high-speed 3G/4G LTE mobile connection with the DWM-312 4G LTE M2M Router, and enjoy fast downlink speeds of up to 150 Mbps and uplink speeds up to 50 Mbps, giving you the speed you need for fast, responsive Internet access. Deploy it in a remote location to access IP cameras and systems remotely. The blazing fast LTE connection allows multiple users to access e-mail and stream music and video on the go. Configurable dual-SIM fallback provides reliability and ?exibility in mixed network environments.
The DWM-312 4G LTE M2M Router's integrated VPN Client and Server support almost any VPN policy. The router's hardware engine can support and manage multiple VPN configurations. It supports IPSec, PPTP, L2TPv2, and GRE protocols in Server mode, and handles pass-through traffic as well. Advanced VPN configuration options include multiple encryption options, key management, negotiation modes, and VPN authentication using an internal user database.
The industrial grade casing means the DWM-312 provides reliable high-speed connectivity in extreme conditions. The corrosion-resistant zinc-plated steel case and wide operating temperature and humidity tolerance mean that the DWM-312 is ready for the most demanding M2M applications in virtually any environment. Wall mounts allow the DWM-312 to be mounted virtually anywhere for optimal connectivity. Flexible power input allows the router to be powered by any convenient power source.
4G LTE dual SIM router with advanced VPN
The D-Link DWM-312 4G LTE M2M Router is an easy-to-deploy, high performance 3G/4G router. It features a dedicated Fast Ethernet port and dual-SIM 4G LTE mobile broadband for maximum redundancy and ?exibility for intense Machine to Machine applications. Powerful VPN tools and advanced remote management combined with ease of use make the DWM-312 ideal for both large-scale and individual deployments. -
Connectivity where you need it most
Easily connect to your high-speed 3G/4G LTE mobile connection with the DWM-312 4G LTE M2M Router, and enjoy fast downlink speeds of up to 150 Mbps and uplink speeds up to 50 Mbps, giving you the speed you need for fast, responsive Internet access. Deploy it in a remote location to access IP cameras and systems remotely. The blazing fast LTE connection allows multiple users to access e-mail and stream music and video on the go. Configurable dual-SIM fallback provides reliability and ?exibility in mixed network environments. -
Reliable high speed virtual private networks
The DWM-312 4G LTE M2M Router's integrated VPN Client and Server support almost any VPN policy. The router's hardware engine can support and manage multiple VPN configurations. It supports IPSec, PPTP, L2TPv2, and GRE protocols in Server mode, and handles pass-through traffic as well. Advanced VPN configuration options include multiple encryption options, key management, negotiation modes, and VPN authentication using an internal user database. -
Robust
 - D-Link DWM-312 - wireless cellular modem - 4G LTE
 - Wireless cellular modem - Ethernet 100
- Form Factor
 - External
- Max Transfer Rate
 - 150 Mbps
- Mobile Communication Protocol
 - LTE, UMTS
- Mobile Band
 - UMTS 850/900/1900/2100 / LTE 700/800/850/900/1800/1900/2100/2300/2600
 - 7 cm x 9.3 cm x 2.4 cm
 - Limited lifetime warranty
- Form Factor
 - External
Modem
- Bus
 - Ethernet 100
- Connectivity Technology
 - Wireless
- Max Transfer Rate
 - 150 Mbps
- Mobile Band
 - LTE, UMTS
- Antenna
 - External detachable
- Antenna Qty
 - 2
 - IPSec, PPTP, L2TPv2
- Remote Management Protocol
 - SNMP
 - VPN support, Generic Routing Encapsulation (GRE)
 - 1 x 100Base-TX - RJ-45
- SIM Card Supported
 - Regular (mini-SIM) x 2
 - Limited warranty - lifetime
 - 7 cm
 - 9.3 cm
 - 2.4 cm
