D-Link 48-port 10GBase-T, 6-port 100G QSFP28 interfaces switch
Quicklinx: J7K3WS00 Mfr#: DXS-3610-54T/SI
£11,786.61 ex VAT
£14,143.93 inc VAT
The DXS-3610 Layer 3 stackable 10G/100G managed OpenFlow switches are compatible with SDN-enabled network architecture for deployment in high-performance datacenter, enterprise, and campus applications. Hot-swappable PSU and fan modules with load sharing capabilities significantly reduce network downtime and power consumption.
  • Robust performance
    With a switching capacity of 2.16 Tbps and a forwarding rate of 1.60704 Mpps, this switch is engineered to handle demanding network environments, ensuring efficient data flow and high-speed connectivity.
  • Comprehensive connectivity
    Equipped with 48 10GBase-T ports and 6 dual-speed 40/100 Gbit QSFP28/QSFP+ ports, the D-Link DXS 3610-54T offers versatile connection options for a wide range of devices and network configurations.
  • Advanced Layer 3 switching
    Supports a suite of Layer 3 protocols including OSPF, BGP, and VRRP, enabling complex routing, redundancy, and network segmentation capabilities for enhanced network efficiency and reliability.
  • Enhanced security features
    Features such as RADIUS, TACACS+, SSH2, and support for encryption algorithms like SSL and TLS 1.2 provide a secure network environment by safeguarding data and controlling access.
  • Efficient network management
    Manageable via CLI, SNMP, RMON, and more, this switch offers comprehensive tools for monitoring and managing network performance, ensuring optimal operation and quick troubleshooting.
D-Link DXS 3610-54T - switch - 54 ports - Managed - rack-mountable
Switch - 54 ports - L3 - Managed - stackable
Enclosure Type
Front to back airflow rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
48 x 10 Gigabit Ethernet + 6 x 40 Gigabit QSFP+ / 100 Gigabit QSFP28
Performance
Switching capacity: 2.16 Tbps , Forwarding rate: 1.60704 Gpps
Packet buffer size: 32 MB , IPv4 routes (static): up to 32000 , IPv6 routes (static): up to 16000 , IPv4 forwarding entries: up to 144000 , IPv6 forwarding entries: up to 144000
MAC Address Table Size
288K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
RIP-1, RIP-2, BGP, IGMPv2, IGMP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, OSPFv3, PIM-SSM, DVMRPv3, MLDv2, MLD, VRRPv2, MPLS, VRRPv3, MSTP, RSTP, STP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, SNMP 3, SNMP 2c, CLI, SMTP
DoS attack prevention, SNTP support, sFlow, DHCP snooping, QoS, MPLS VPN, LLDP support, DNS relay, VRF, NDP, VCCV, GVRP, SNMP support, GRE, ToS, DSCP support, ERPS, 5 fans, OpenFlow support, VPLS, PFC, BPDU, LDP, ERPS v2, WDRR, SRM, LLDP-MED, Ethernet OAM, WRR, MAC based VLAN, loopback detection, port-based VLAN, D-Link DDP, CIR, Microsoft NLB
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1v, IEEE 802.1ag, IEEE 802.1AX, IEEE 802.1Qbb, ITU-T Y.1731
Power Redundancy
44.1 cm x 48.744 cm x 4.35 cm
9.88 kg
Enclosure Type
Subtype
10 Gigabit Ethernet
Ports
Performance
288K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Encryption Algorithm
SSL, TLS 1.2
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
48 x 10GBase-T RJ-45 , 6 x 100Gbit/40Gbit LAN QSFP28/QSFP+ , 1 x console RJ-45 , 1 x management (Gigabit LAN) RJ-45 , 1 x alarm RJ-45 , 1 x micro-USB 2.0 Type A
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
4 rubber feet, 2 x 19" mounting brackets
1 x console cable , 1 x micro-USB cable
Rack Mounting Kit
Included
VCCI, C-Tick, cUL, CB, IC, FCC, LVD
44.1 cm
48.744 cm
4.35 cm
9.88 kg
45 °C
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Brand: D-Link
Price Range Ex VAT: £1500+
