D-Link 48-port 10G SFP+, 6-port 100G QSFP28 interfaces switch
Quicklinx: J7K2WS00 Mfr#: DXS-3610-54S/SI
£8,566.84 ex VAT
£10,280.20 inc VAT
The DXS-3610 Layer 3 stackable 10G/100G managed OpenFlow switches are compatible with SDN-enabled network architecture for deployment in high-performance datacenter, enterprise, and campus applications. Hot-swappable PSU and fan modules with load sharing capabilities significantly reduce network downtime and power consumption.
  • Robust performance
    With a switching capacity of 2.16 Tbps and a forwarding rate of 1.60704 Gbps, this switch is engineered to handle demanding network environments, ensuring smooth data transmission across multiple channels.
  • Comprehensive security
    Incorporates advanced security features including RADIUS, Secure Shell v.2 (SSH2), and TACACS+ authentication methods, along with SSL and TLS 1.2 encryption algorithms, to safeguard network integrity and protect against unauthorized access.
  • Versatile connectivity
    Offers a wide range of connectivity options with 48 10 Gigabit SFP+ ports and 6 40/100 Gigabit QSFP+/QSFP28 ports, complemented by dedicated console, management, and alarm ports, facilitating flexible network configurations and expansions.
  • Enhanced reliability
    Designed for continuous operation with an MTBF of 94,262 hours, front to back airflow for optimal cooling, and hot-plug redundant power supplies, ensuring uninterrupted service and longevity.
  • Advanced networking features
    Supports a comprehensive suite of Layer 3 switching, routing protocols, and advanced features such as Quality of Service (QoS), Virtual Routing and Forwarding (VRF), and OpenFlow support, enabling efficient network management and customization.
D-Link DXS 3610-54S - switch - 54 ports - Managed - rack-mountable
Switch - 54 ports - L3 - Managed - stackable
Enclosure Type
Front to back airflow rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
48 x 10 Gigabit SFP+ + 6 x 40 Gigabit QSFP+ / 100 Gigabit QSFP28
Performance
Switching capacity: 2.16 Tbps , Forwarding rate: 1.60704 Gpps
Packet buffer size: 32 MB , IPv4 routes (static): up to 32000 , IPv6 routes (static): up to 16000 , IPv4 forwarding entries: up to 144000 , IPv6 forwarding entries: up to 144000
MAC Address Table Size
288K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
RIP-1, RIP-2, BGP, IGMPv2, IGMP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, OSPFv3, PIM-SSM, DVMRPv3, MLDv2, MLD, VRRPv2, MPLS, VRRPv3, MSTP, RSTP, STP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, SNMP 3, SNMP 2c, CLI, SMTP
DoS attack prevention, SNTP support, sFlow, DHCP snooping, QoS, MPLS VPN, LLDP support, DNS relay, VRF, NDP, VCCV, GVRP, SNMP support, GRE, ToS, DSCP support, ERPS, 5 fans, OpenFlow support, VPLS, PFC, BPDU, LDP, ERPS v2, WDRR, SRM, LLDP-MED, Ethernet OAM, WRR, MAC based VLAN, loopback detection, port-based VLAN, D-Link DDP, CIR, Microsoft NLB
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1v, IEEE 802.1ag, IEEE 802.1AX, IEEE 802.1Qbb, ITU-T Y.1731
Power Redundancy
44.1 cm x 48.744 cm x 4.35 cm
9.8 kg
Enclosure Type
Subtype
10 Gigabit Ethernet
Ports
Performance
288K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Encryption Algorithm
SSL, TLS 1.2
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
48 x 10GBase-X SFP+ , 6 x 100Gbit/40Gbit LAN QSFP28/QSFP+ , 1 x console RJ-45 , 1 x management (Gigabit LAN) RJ-45 , 1 x alarm , 1 x micro-USB 2.0 Type A
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Consumption Stand by
120.6 Watt
4 rubber feet, 2 x 19" mounting brackets
1 x console cable , 1 x micro-USB cable
Rack Mounting Kit
Included
MTBF
94,262 hours
VCCI, C-Tick, cUL, CB, IC, FCC, LVD
44.1 cm
48.744 cm
4.35 cm
9.8 kg
45 °C
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Brand: D-Link
Price Range Ex VAT: £1500+
