D-Link 48-port 10G SFP+, 6-port 100G QSFP28 interfaces switch
Quicklinx: J7K2WS00 Mfr#: DXS-3610-54S/SI
Type: 10 Gigabit Ethernet
Ports: 54
Managed: Yes
£8,363.31 ex VAT
£10,035.97 inc VAT
The DXS-3610 Layer 3 stackable 10G/100G managed OpenFlow switches are compatible with SDN-enabled network architecture for deployment in high-performance datacenter, enterprise, and campus applications. Hot-swappable PSU and fan modules with load sharing capabilities significantly reduce network downtime and power consumption.
  • Robust performance
    With a switching capacity of 2.16 Tbps and a forwarding rate of 1.60704 Gbps, this switch is engineered to handle demanding network environments, ensuring smooth data transmission across multiple channels.
  • Comprehensive security
    Incorporates advanced security features including RADIUS, Secure Shell v.2 (SSH2), and TACACS+ authentication methods, along with SSL and TLS 1.2 encryption algorithms, to safeguard network integrity and protect against unauthorized access.
  • Versatile connectivity
    Offers a wide range of connectivity options with 48 10 Gigabit SFP+ ports and 6 40/100 Gigabit QSFP+/QSFP28 ports, complemented by dedicated console, management, and alarm ports, facilitating flexible network configurations and expansions.
  • Enhanced reliability
    Designed for continuous operation with an MTBF of 94,262 hours, front to back airflow for optimal cooling, and hot-plug redundant power supplies, ensuring uninterrupted service and longevity.
  • Advanced networking features
    Supports a comprehensive suite of Layer 3 switching, routing protocols, and advanced features such as Quality of Service (QoS), Virtual Routing and Forwarding (VRF), and OpenFlow support, enabling efficient network management and customization.
D-Link DXS 3610-54S - switch - 54 ports - Managed - rack-mountable
Switch - 54 ports - L3 - Managed - stackable
Enclosure Type
Front to back airflow rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
48 x 10 Gigabit SFP+ + 6 x 40 Gigabit QSFP+ / 100 Gigabit QSFP28
Performance
Switching capacity: 2.16 Tbps , Forwarding rate: 1.60704 Gpps
Packet buffer size: 32 MB , IPv4 routes (static): up to 32000 , IPv6 routes (static): up to 16000 , IPv4 forwarding entries: up to 144000 , IPv6 forwarding entries: up to 144000
MAC Address Table Size
288K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
MPLS, BGP, IGMP, MLD, PIM-DM, PIM-SM, PIM-SSM, STP, MSTP, RSTP, MLDv2, IGMPv2, IGMPv3, OSPFv2, OSPFv3, RIP-1, RIP-2, VRRPv2, VRRPv3, DVMRPv3
Remote Management Protocol
CLI, SNMP 1, SNMP 2c, SNMP 3, SMTP, RMON 1, RMON 2
PFC, ERPS, ERPS v2, OpenFlow support, Ethernet OAM, QoS, MPLS VPN, SRM, SNMP support, 5 fans, loopback detection, GRE, NDP, MAC based VLAN, port-based VLAN, GVRP, WDRR, WRR, DSCP support, ToS, CIR, DHCP snooping, BPDU, DoS attack prevention, DNS relay, LLDP support, LLDP-MED, Microsoft NLB, sFlow, SNTP support, D-Link DDP, LDP, VPLS, VRF, VCCV
IEEE 802.1Qbb, IEEE 802.3ah, IEEE 802.1ag, ITU-T Y.1731, IEEE 802.1x, IEEE 802.1Q, IEEE 802.1AX, IEEE 802.1D, IEEE 802.1s, IEEE 802.1w, IEEE 802.1v
Power Redundancy
44.1 cm x 48.744 cm x 4.35 cm
9.8 kg
Enclosure Type
Subtype
10 Gigabit Ethernet
Ports
Performance
288K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Encryption Algorithm
TLS 1.2, SSL
Authentication Method
TACACS+, RADIUS, Secure Shell v.2 (SSH2)
48 x 10GBase-X SFP+ , 6 x 100Gbit/40Gbit LAN QSFP28/QSFP+ , 1 x console RJ-45 , 1 x management (Gigabit LAN) RJ-45 , 1 x alarm , 1 x micro-USB 2.0 Type A
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Consumption Stand by
120.6 watt
2 x 19" mounting brackets, 4 rubber feet
1 x console cable , 1 x micro-USB cable
Rack Mounting Kit
Included
MTBF
94,262 hours
CB, cUL, LVD, FCC, C-Tick, IC, VCCI
44.1 cm
48.744 cm
4.35 cm
9.8 kg
45 °C
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 54
Managed: Yes
Brand: D-Link
Price Range Ex VAT: £1500+
