D-Link's 40G QSFP+ module series are hot-swappable QSFP+ transceivers that plug into QSFP+ slots on switches and support 40G Ethernet. The D-Link 40GBASE QSFP+ module series transceivers offer customers a wide variety of 40G Ethernet connectivity options for data centers, enterprise wiring closets, and service provider transport applications.
- D-Link DEM QX01Q-SR4 - QSFP+ transceiver module - 40GbE
- QSFP+ transceiver module - MPO multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 40GBASE-SR4
- Data Transfer Rate
- 40 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 40GbE
- 11.58 cm x 1.84 cm x 1.3328 cm
- 40 g
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 40GBASE-SR4
- 40GbE
- 40 Gbps
- 850 nm
- Digital Diagnostics Monitoring (DDM)
- IEEE 802.3ba
- 1 x Ethernet 40GBASE-SR4 - MPO multi-mode female
- MTBF
- 4,420,000 hours
- FCC Class B certified, CSA, TUV, RoHS, FDA, CDRH, MSA, VCCI Class B, OM4, OM3
- 11.58 cm
- 1.84 cm
- 1.3328 cm
- 40 g
- 0 °C
- 70 °C
- 0 - 85%
