D-Link 40GBase-SR4 QSFP+ Multi-mode Transceiver, 100M/ 150M
Quicklinx: J7LYWS00 Mfr#: DEM-QX01Q-SR4
£273.96 ex VAT
£328.75 inc VAT
D-Link's 40G QSFP+ module series are hot-swappable QSFP+ transceivers that plug into QSFP+ slots on switches and support 40G Ethernet. The D-Link 40GBASE QSFP+ module series transceivers offer customers a wide variety of 40G Ethernet connectivity options for data centers, enterprise wiring closets, and service provider transport applications.
  • Quad Small Form-Factor Pluggable Plus format
    The transceivers use the Quad Small Form-factor Pluggable Plus format (QSFP+) connectors, which integrate four transmitting and four receiving channels.
  • Hot pluggable
    All D-Link transceivers are hot pluggable. You can connect a transceiver while the system is powered on without causing any issues, and easily swap one for another without having to reboot the switch each time. This permits modules to be added or removed without interrupting the network, facilitating maintenance and greatly reducing downtime.
  • 40G Ethernet speeds
    The transceivers all support 40G Ethernet, which results in very fast data transmissions.
D-Link DEM QX01Q-SR4 - QSFP+ transceiver module - 40GbE
QSFP+ transceiver module - MPO multi-mode
Plug-in module
Cabling Type
40GBASE-SR4
Data Transfer Rate
40 Gbps
Optical Wave Length
850 nm
40GbE
11.58 cm x 1.84 cm x 1.3328 cm
40 g
Plug-in module
Wired
Cabling Type
40GBASE-SR4
40GbE
Data Transfer Rate
40 Gbps
Optical Wave Length
850 nm
Digital Diagnostics Monitoring (DDM)
IEEE 802.3ba
1 x Ethernet 40GBASE-SR4 - MPO multi-mode female
MTBF
4,420,000 hours
FCC Class B certified, CSA, TUV, RoHS, FDA, CDRH, MSA, VCCI Class B, OM4, OM3
11.58 cm
1.84 cm
1.3328 cm
40 g
70 °C
0 - 85%
Brand: D-Link
