D-Link 40GBASE-LR4 QSFP+ Single-Mode Transceiver, 10km
Quicklinx: J7LZWS00 Mfr#: DEM-QX10Q-LR4
£1,758.72 ex VAT
£2,110.46 inc VAT
The D-Link DEM QX10Q-LR4 QSFP+ transceiver module offers high-speed data transfer rates of up to 40 Gbps and an extended reach of up to 10 km. Designed for reliability and performance, this plug-in module is an ideal solution for expanding or upgrading network infrastructures. It supports Ethernet 40GBase-LR4 cabling type and comes equipped with LC single-mode connectors, ensuring compatibility with a wide range of networking equipment. Compliant with essential standards such as IEEE 802.3ba, CSA, FCC, and more, the D-Link DEM QX10Q-LR4 is built to meet the demands of modern networks. Features like Digital Diagnostics Monitoring (DDM) provide real-time insights into the network's performance, enhancing its reliability and user experience. With an impressive MTBF of 4,420,000 hours, users can trust in the module's durability and performance, making it a smart investment for any organization looking to enhance its network capabilities.
  • Robust connectivity
    The D-Link DEM QX10Q-LR4 QSFP+ transceiver module offers a reliable wired connectivity solution, ensuring stable and high-speed data transfer rates of up to 40 Gbps for demanding network environments.
  • Extended reach
    Designed to meet the needs of long-distance networking, this module boasts an impressive max transfer distance of 10 km, facilitated by LC single-mode connectors, making it ideal for extended network setups.
  • High compatibility
    Compliant with a wide range of standards including IEEE 802.3ba and MSA, the D-Link DEM QX10Q-LR4 ensures broad compatibility with various networking equipment, simplifying integration into existing setups.
  • Enhanced durability
    With an MTBF of 4,420,000 hours and adherence to stringent standards such as RoHS and CDRH, this module is built for long-term reliability and compliance with environmental and safety regulations.
  • Advanced features
    Equipped with Digital Diagnostics Monitoring (DDM), this transceiver module offers advanced features for real-time monitoring of critical parameters, enhancing network reliability and performance.
D-Link DEM QX10Q-LR4 - QSFP+ transceiver module - 40GbE
QSFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
40GBase-LR4
Data Transfer Rate
40 Gbps
Optical Wave Length
1271 nm / 1291 nm / 1311 nm / 1331 nm
40GbE
Max Transfer Distance
10 km
11.8 cm x 1.84 cm x 1.29 cm
40 g
Plug-in module
Wired
Cabling Type
40GBase-LR4
40GbE
Data Transfer Rate
40 Gbps
Optical Wave Length
10 km
IEEE 802.3ba
1 x Ethernet 40GBase-LR4 - LC single-mode x 2
MTBF
4,420,000 hours
FCC Class B certified, CSA, TUV, RoHS, FDA, CDRH, MSA, VCCI Class B
11.8 cm
1.84 cm
1.29 cm
40 g
70 °C
0 - 85%
Brand: D-Link
Price Range Ex VAT: £1500+
