If you need to control several computers at the same time (such as in a computer room), the DKVM-4K 4-port KVM Switch saves you the money and space by allowing you to control you're the computers from a set of keyboard, monitor and mouse. You may have a better, bigger monitor and want to connect all 4 PCs to it, the DKVM-4K allows you to do this.
The DKVM-4K allows you to manage port traffic and boot up the attached PCs. A control button located on the top of the DKVM-4K gives you one touch access to your attached PCs. Featuring hot-plug, auto-scan, keyboard hot-keys and audible feedback, this switch makes it simple to manage all of your computers.
The DKVM-4K supports VGA, SVGA, and MultiSync monitors at up to 2048 x 1536 resolution. Support for Microsoft IntelliMouse is provided.
- D-Link DKVM 4K - KVM switch - 4 ports
- Subtype
- KVM
- Ports
- 4 x KVM port(s)
- KVM Users Qty
- 1 local user
- 10.2 cm x 17.8 cm x 3 cm
- 0.3 kg
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 4 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- PS/2
- Max Resolution
- 2048 x 1536
- Status Indicators
- Port status
- 4 x keyboard (PS/2) , 4 x mouse (PS/2) , 4 x VGA HD-15 , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x VGA HD-15
- Cables Included
- 2 x keyboard / mouse / video cable - 1.8 m
- 10.2 cm
- 17.8 cm
- 3 cm
- 0.3 kg
- 0 °C
- 50 °C
- 0 - 80%
Customer reviews
Write a review for the D-Link 4-Port KVM Pro-Connect Switch here!
question - cables
Reviewed by Anonymous Review Posted 02/05/2006
Question - does this actually come with cables? (above it says it does, but the dlink website says different) Anyone?
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
