The D-Link DMS 3130-30TS switch is engineered to meet the demands of modern networks, offering a blend of performance, security, and connectivity. With its 24 100/1000/2.5G RJ-45 ports, 2 multi-gigabit ports, and 4 10Gbit/25Gbit SFP28 uplinks, this device provides flexible options for connecting devices across the network. Its advanced Layer 3 switching capabilities enable efficient routing and traffic management, ensuring smooth operation even in high-demand scenarios.
Security is a priority, with features like RADIUS and TACACS+ authentication, SSL/TLS encryption, and advanced access control lists (ACLs) safeguarding the network against unauthorized access and threats. The switch's high switching capacity and forwarding rate support the rapid movement of large data volumes, making it suitable for businesses with intensive data transfer needs.
Designed for durability, the D-Link DMS 3130-30TS boasts an impressive MTBF, ensuring long-term reliability. Its stackable nature allows for network expansion without complexity, making it an ideal choice for growing businesses looking for a scalable networking solution.
Enhanced connectivity
With a comprehensive array of ports including 24 100/1000/2.5G RJ-45, 2 100/1000/2.5G/5G/10G RJ-45, and 4 10Gbit/25Gbit SFP28 uplinks, this switch ensures versatile connectivity options for a wide range of network needs. -
Robust security features
Equipped with RADIUS and TACACS+ authentication methods, alongside SSL and TLS encryption algorithms, the D-Link DMS 3130-30TS offers a secure networking environment to protect against unauthorized access. -
High performance
Boasting a switching capacity of 360 Gbps and a bidirectional forwarding rate of 268 Mpps, this switch is designed to handle high volumes of traffic, ensuring efficient data flow across the network. -
Advanced network management
Support for SNMP, RMON, HTTP, HTTPS, and SSH protocols allows for comprehensive remote management, facilitating efficient network monitoring and configuration. -
Durable and reliable
With an MTBF of over 270,340 hours and built-in fans for cooling, the D-Link DMS 3130-30TS is built for longevity and reliability in demanding operational environments.
- D-Link DMS 3130-30TS - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - L3 - Managed - stackable
- Enclosure Type
- Rack-mountable
- Subtype
- 5 Gigabit Ethernet / 2.5 Gigabit Ethernet
- Ports
- 24 x 100/1000/2.5G + 2 x 100/1000/2.5G/5G/10G + 4 x 10 Gigabit / 25 Gigabit SFP28
- Performance
- Switching capacity: 360 Gbps , Bidirectional forwarding rate (64-byte packet size): 268 Mpps , Stacking bandwidth: 200 Gbps
- Capacity
- Packet buffer size: 4 MB , Units per virtual stack: 32 , Queues per port: 8 , Link aggregation groups: 32 , IGMP groups: 1024 , MLD groups: 1024 , VLAN groups: 4094 , ACL entries (ingress): 3072 , ACL entries (egress): 1024 , IPv4 routes (ARP entries): 4096 , IPv6 ND entries: 1024 , IP interfaces: 128
- MAC Address Table Size
- 32768 entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- RIP-1, RIP-2, IGMPv2, IGMP, OSPFv2, PIM-SM, static IP routing, IGMPv3, OSPFv3, ECMP, RIPng, MLDv2, MLD, VRRPv2, VRRPv3, MSTP, RSTP, STP
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, SSH-2, CLI, OAM, SMTP, NTP, DHCP, IPv4, IPv6
- Flow control, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, QoS, MLD snooping, reset button, Cable Diagnostics Function, fanless, LLDP support, DHCP client, built-in DIP switch, tagged VLAN, ONVIF support, ERPS, 6KV Surge protection, Voice VLAN, VLAN management, EEE, WRR, HOL Blocking Prevention, loopback detection, port-based VLAN, Unknown Storm Control, isolate mode, Green Technology, Asymmetric VLAN, UDP support, TCP support, Auto Surveillance VLAN, PD-Alive
- IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1w, IEEE 802.3az, ITU-T G.8032
- Power
- AC 100-240 V (50/60 Hz)
- Power Redundancy
- Optional
- 44 cm x 25 cm x 4.4 cm
- 3.63 kg
- Localisation
- United Kingdom
- Limited lifetime warranty with product registration
- Enclosure Type
- Rack-mountable
- Subtype
- Ports
- Performance
- Capacity
- 32768 entries
- 9KB
- Max Units In A Stack
- 9
- Routing Protocol
- Encryption Algorithm
- SSL, TLS 1.0, SSL 3.0, SSL 2.0, TLS 1.1, TLS 1.2
- Authentication Method
- RADIUS, TACACS+
- Built-in Devices
- 2 x fans
- Status Indicators
- Power, RPS (Redundant Power Supply), USB, console, link/activity/speed, management, fan failure, stack ID
- 24 x 100/1000/2.5G RJ-45 uplink , 2 x 100/1000/2.5G/5G/10G RJ-45 uplink , 4 x 10Gbit/25Gbit SFP28 uplink , 1 x console RJ-45 , 1 x management (Gigabit LAN) RJ-45 , 1 x USB 2.0 Type A
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 1
- Max Supported Qty
- 2
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1
- Voltage Required
- Power Consumption Stand by
- 43.84 Watt
- MTBF
- 270,340.81 hours
- FCC Class A certified, BSMI, cUL, CB, IC, VCCI Class A, RCM
- Localisation
- United Kingdom
- 44 cm
- 25 cm
- 4.4 cm
- 3.63 kg
- Limited warranty - lifetime
- 0 °C
- 50 °C
- 10 - 90% RH
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% RH
D-Link SFP+ Direct Attach Stacking Cable, 1M | In Stock | £174.80 |
