D-Link 30-port Layer 3 Stackable Multi-Gigabit Managed Switch
Quicklinx: J7JXWS00 Mfr#: DMS-3130-30TS/B
£1,886.74 ex VAT
£2,264.08 inc VAT
The D-Link DMS 3130-30TS switch is engineered to meet the demands of modern networks, offering a blend of performance, security, and connectivity. With its 24 100/1000/2.5G RJ-45 ports, 2 multi-gigabit ports, and 4 10Gbit/25Gbit SFP28 uplinks, this device provides flexible options for connecting devices across the network. Its advanced Layer 3 switching capabilities enable efficient routing and traffic management, ensuring smooth operation even in high-demand scenarios.
Security is a priority, with features like RADIUS and TACACS+ authentication, SSL/TLS encryption, and advanced access control lists (ACLs) safeguarding the network against unauthorized access and threats. The switch's high switching capacity and forwarding rate support the rapid movement of large data volumes, making it suitable for businesses with intensive data transfer needs.
Designed for durability, the D-Link DMS 3130-30TS boasts an impressive MTBF, ensuring long-term reliability. Its stackable nature allows for network expansion without complexity, making it an ideal choice for growing businesses looking for a scalable networking solution.
  • Enhanced connectivity
    With a comprehensive array of ports including 24 100/1000/2.5G RJ-45, 2 100/1000/2.5G/5G/10G RJ-45, and 4 10Gbit/25Gbit SFP28 uplinks, this switch ensures versatile connectivity options for a wide range of network needs.
  • Robust security features
    Equipped with RADIUS and TACACS+ authentication methods, alongside SSL and TLS encryption algorithms, the D-Link DMS 3130-30TS offers a secure networking environment to protect against unauthorized access.
  • High performance
    Boasting a switching capacity of 360 Gbps and a bidirectional forwarding rate of 268 Mpps, this switch is designed to handle high volumes of traffic, ensuring efficient data flow across the network.
  • Advanced network management
    Support for SNMP, RMON, HTTP, HTTPS, and SSH protocols allows for comprehensive remote management, facilitating efficient network monitoring and configuration.
  • Durable and reliable
    With an MTBF of over 270,340 hours and built-in fans for cooling, the D-Link DMS 3130-30TS is built for longevity and reliability in demanding operational environments.
D-Link DMS 3130-30TS - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
5 Gigabit Ethernet / 2.5 Gigabit Ethernet
Ports
24 x 100/1000/2.5G + 2 x 100/1000/2.5G/5G/10G + 4 x 10 Gigabit / 25 Gigabit SFP28
Performance
Switching capacity: 360 Gbps , Bidirectional forwarding rate (64-byte packet size): 268 Mpps , Stacking bandwidth: 200 Gbps
Packet buffer size: 4 MB , Units per virtual stack: 32 , Queues per port: 8 , Link aggregation groups: 32 , IGMP groups: 1024 , MLD groups: 1024 , VLAN groups: 4094 , ACL entries (ingress): 3072 , ACL entries (egress): 1024 , IPv4 routes (ARP entries): 4096 , IPv6 ND entries: 1024 , IP interfaces: 128
MAC Address Table Size
32768 entries
Jumbo Frame Support
9KB
Routing Protocol
RIP-1, RIP-2, IGMPv2, IGMP, OSPFv2, PIM-SM, static IP routing, IGMPv3, OSPFv3, ECMP, RIPng, MLDv2, MLD, VRRPv2, VRRPv3, MSTP, RSTP, STP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, SSH-2, CLI, OAM, SMTP, NTP, DHCP, IPv4, IPv6
Flow control, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, QoS, MLD snooping, reset button, Cable Diagnostics Function, fanless, LLDP support, DHCP client, built-in DIP switch, tagged VLAN, ONVIF support, ERPS, 6KV Surge protection, Voice VLAN, VLAN management, EEE, WRR, HOL Blocking Prevention, loopback detection, port-based VLAN, Unknown Storm Control, isolate mode, Green Technology, Asymmetric VLAN, UDP support, TCP support, Auto Surveillance VLAN, PD-Alive
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1w, IEEE 802.3az, ITU-T G.8032
AC 100-240 V (50/60 Hz)
Power Redundancy
Optional
44 cm x 25 cm x 4.4 cm
3.63 kg
United Kingdom
Limited lifetime warranty with product registration
Enclosure Type
Rack-mountable
Subtype
Ports
Performance
32768 entries
Jumbo Frame Support
9KB
Max Units In A Stack
9
Routing Protocol
Encryption Algorithm
SSL, TLS 1.0, SSL 3.0, SSL 2.0, TLS 1.1, TLS 1.2
Authentication Method
RADIUS, TACACS+
Built-in Devices
2 x fans
Status Indicators
Power, RPS (Redundant Power Supply), USB, console, link/activity/speed, management, fan failure, stack ID
24 x 100/1000/2.5G RJ-45 uplink , 2 x 100/1000/2.5G/5G/10G RJ-45 uplink , 4 x 10Gbit/25Gbit SFP28 uplink , 1 x console RJ-45 , 1 x management (Gigabit LAN) RJ-45 , 1 x USB 2.0 Type A
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Redundancy Scheme
1+1
Power Consumption Stand by
43.84 Watt
MTBF
270,340.81 hours
FCC Class A certified, BSMI, cUL, CB, IC, VCCI Class A, RCM
United Kingdom
44 cm
25 cm
4.4 cm
3.63 kg
Limited warranty - lifetime
50 °C
10 - 90% RH
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% RH
J7JX D-Link SFP+ Direct Attach Stacking Cable, 1M In Stock £172.42
Brand: D-Link
Price Range Ex VAT: £1500+
