The D-Link DMS 3130-30PS switch is engineered to meet the demands of modern network environments, offering a blend of high-speed performance, robust security, and versatile connectivity. With a 400 Gbps switching capacity and support for up to 32 link aggregation groups, it's designed to facilitate seamless data flow, making it suitable for businesses with high data throughput requirements. Security is a priority, with advanced features like RADIUS and TACACS+ authentication, SSL/TLS encryption, and comprehensive access control lists (ACLs) to protect against unauthorized access and data breaches.
Power over Ethernet (PoE) capabilities further enhance its utility, providing up to 60 W per port on 8 PoE++ ports, enabling the switch to power high-performance devices directly through network cables. This eliminates the need for separate power sources, simplifying deployment of devices like wireless access points and surveillance cameras. Additionally, the switch's cooling system, featuring 2 built-in fans, ensures it operates efficiently, even under heavy load. With its wide array of ports, including multi-gigabit and 10G/25G SFP28 uplinks, the D-Link DMS 3130-30PS offers flexible connectivity options to accommodate a variety of network architectures, making it a versatile choice for any organization looking to upgrade its network infrastructure.
Advanced cooling system
Equipped with 2 built-in fans, this switch ensures optimal performance by maintaining a cool operating environment, even under heavy network traffic conditions. -
Robust security features
With support for RADIUS and TACACS+ authentication methods, alongside SSL and TLS encryption algorithms, this switch offers a secure networking environment, safeguarding against unauthorized access and data breaches. -
High-capacity networking
Featuring a 400 Gbps switching capacity and support for up to 32 link aggregation groups, this switch is designed to handle extensive data throughput, making it ideal for high-demand network environments. -
Comprehensive PoE support
With 16 PoE+ and 8 PoE++ ports, delivering up to 60 W per port, this switch can power a wide range of devices, including high-performance wireless access points and surveillance cameras, directly through the network cables. -
Versatile connectivity options
Offering a variety of ports including 100/1000/2.5G, 5G, and 10GBase-T, along with 10 Gigabit / 25 Gigabit SFP28 for uplinks, this switch provides flexible connection options to meet diverse networking requirements.
- D-Link DMS 3130-30PS - switch - multi-gigabit - 30 ports - Managed - rack-mountable
- Switch - 30 ports - L3 - Managed - stackable
- Enclosure Type
- Rack-mountable
- Subtype
- 5 Gigabit Ethernet / 2.5 Gigabit Ethernet
- Ports
- 16 x 100/1000/2.5G (PoE+) + 8 x 100/1000/2.5G/5G (PoE++) + 2 x 100/1000/2.5G/5G/10GBase-T + 4 x 10 Gigabit / 25 Gigabit SFP28
- Power Over Ethernet (PoE)
- PoE++
- PoE Budget
- 740 W
- Performance
- Switching capacity: 400 Gbps , Bidirectional forwarding rate (64-byte packet size): 298 Mpps , Stacking bandwidth: 200 Gbps
- Capacity
- Packet buffer size: 4 MB , Units per virtual stack: 32 , Queues per port: 8 , Link aggregation groups: 32 , IGMP groups: 1024 , MLD groups: 1024 , VLAN groups: 4094 , ACL entries (ingress): 3072 , ACL entries (egress): 1024 , IPv4 routes (ARP entries): 2048 , IPv6 ND entries: 1024 , IP interfaces: 128 , IPv4 routing table entries: 1000 , IPv6 routing table entries: 512 , IPv4 forwarding table entries: 4000 , IPv6 forwarding table entries: 2000
- MAC Address Table Size
- 32768 entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- RIP-1, RIP-2, IGMPv2, IGMP, OSPFv2, PIM-SM, static IP routing, IGMPv3, OSPFv3, ECMP, RIPng, MLDv2, MLD, VRRPv2, VRRPv3, MSTP, RSTP, STP
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, SSH-2, CLI, OAM, SMTP, NTP, DHCP, IPv4, IPv6
- Flow control, VLAN support, DoS attack prevention, Broadcast Storm Control, High Availability, Multicast Storm Control, Unicast Storm Control, WRED, sFlow, STP support, ACL support, QoS, DAI, RSPAN, CoS, D-Link SIM, metal housing, ERPS, 6KV Surge protection, LD-VCStack, Link Aggregation, DDM, AAA, VLAN Double Tagging (Q-in-Q), Root Guard, Loop Guard, ERPS v2, flow mirroring, VLAN mirroring, WDRR, WAC, Voice VLAN, CFM, IPMB, RA guard, EEE, BPDU Filter, WRR, HOL Blocking Prevention, loopback detection, D-Link DDP, Asymmetric VLAN, Microsoft NLB, Smart Fans, DAD, DNS support, Auto Surveillance VLAN, Super VLAN
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1v, IEEE 802.1ag, IEEE 802.3at, IEEE 802.1AX, IEEE 802.3bt
- Power
- AC 100-240 V (50/60 Hz)
- Power Redundancy
- Optional
- 44 cm x 47 cm x 4.4 cm
- 6.54 kg
- Localisation
- United Kingdom
- Limited lifetime warranty with product registration
- Enclosure Type
- Rack-mountable
- Subtype
- Ports
- PoE++
- PoE Budget
- 740 W
- Performance
- Capacity
- 32768 entries
- 9KB
- Max Units In A Stack
- 9
- Routing Protocol
- Encryption Algorithm
- SSL, TLS 1.0, SSL 3.0, SSL 2.0, TLS 1.1, TLS 1.2
- Authentication Method
- RADIUS, TACACS+
- Built-in Devices
- 2 x fans
- Status Indicators
- Power, RPS (Redundant Power Supply), USB, console, link/activity/speed, management, fan failure, stack ID
- 16 x 100/1000/2.5G RJ-45 PoE+ , 8 x 100/1000/2.5G/5G RJ-45 PoE++ - 60 W , 2 x 100/1000/2.5G/5G/10G RJ-45 uplink , 4 x 10Gbit/25Gbit SFP28 uplink , 1 x console RJ-45 , 1 x management (Gigabit LAN) RJ-45 , 1 x USB 2.0 Type A
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 1
- Max Supported Qty
- 2
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1
- Voltage Required
- Power Consumption Stand by
- 58.3 Watt
- MTBF
- 277,222.63 hours
- FCC Class A certified, BSMI, cUL, CB, IC, VCCI Class A, RCM
- Localisation
- United Kingdom
- 44 cm
- 47 cm
- 4.4 cm
- 6.54 kg
- Limited warranty - lifetime
- 0 °C
- 50 °C
- 10 - 90% RH
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% RH
