D-Link 30-Port Layer 3 Stackable Multi-Gigabit Managed PoE Switch
Quicklinx: J7JWWS00 Mfr#: DMS-3130-30PS/B
£2,160.91 ex VAT
£2,593.09 inc VAT
The D-Link DMS 3130-30PS switch is engineered to meet the demands of modern network environments, offering a blend of high-speed performance, robust security, and versatile connectivity. With a 400 Gbps switching capacity and support for up to 32 link aggregation groups, it's designed to facilitate seamless data flow, making it suitable for businesses with high data throughput requirements. Security is a priority, with advanced features like RADIUS and TACACS+ authentication, SSL/TLS encryption, and comprehensive access control lists (ACLs) to protect against unauthorized access and data breaches.
Power over Ethernet (PoE) capabilities further enhance its utility, providing up to 60 W per port on 8 PoE++ ports, enabling the switch to power high-performance devices directly through network cables. This eliminates the need for separate power sources, simplifying deployment of devices like wireless access points and surveillance cameras. Additionally, the switch's cooling system, featuring 2 built-in fans, ensures it operates efficiently, even under heavy load. With its wide array of ports, including multi-gigabit and 10G/25G SFP28 uplinks, the D-Link DMS 3130-30PS offers flexible connectivity options to accommodate a variety of network architectures, making it a versatile choice for any organization looking to upgrade its network infrastructure.
  • Advanced cooling system
    Equipped with 2 built-in fans, this switch ensures optimal performance by maintaining a cool operating environment, even under heavy network traffic conditions.
  • Robust security features
    With support for RADIUS and TACACS+ authentication methods, alongside SSL and TLS encryption algorithms, this switch offers a secure networking environment, safeguarding against unauthorized access and data breaches.
  • High-capacity networking
    Featuring a 400 Gbps switching capacity and support for up to 32 link aggregation groups, this switch is designed to handle extensive data throughput, making it ideal for high-demand network environments.
  • Comprehensive PoE support
    With 16 PoE+ and 8 PoE++ ports, delivering up to 60 W per port, this switch can power a wide range of devices, including high-performance wireless access points and surveillance cameras, directly through the network cables.
  • Versatile connectivity options
    Offering a variety of ports including 100/1000/2.5G, 5G, and 10GBase-T, along with 10 Gigabit / 25 Gigabit SFP28 for uplinks, this switch provides flexible connection options to meet diverse networking requirements.
D-Link DMS 3130-30PS - switch - multi-gigabit - 30 ports - Managed - rack-mountable
Switch - 30 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
5 Gigabit Ethernet / 2.5 Gigabit Ethernet
Ports
16 x 100/1000/2.5G (PoE+) + 8 x 100/1000/2.5G/5G (PoE++) + 2 x 100/1000/2.5G/5G/10GBase-T + 4 x 10 Gigabit / 25 Gigabit SFP28
Power Over Ethernet (PoE)
PoE++
PoE Budget
740 W
Performance
Switching capacity: 400 Gbps , Bidirectional forwarding rate (64-byte packet size): 298 Mpps , Stacking bandwidth: 200 Gbps
Packet buffer size: 4 MB , Units per virtual stack: 32 , Queues per port: 8 , Link aggregation groups: 32 , IGMP groups: 1024 , MLD groups: 1024 , VLAN groups: 4094 , ACL entries (ingress): 3072 , ACL entries (egress): 1024 , IPv4 routes (ARP entries): 2048 , IPv6 ND entries: 1024 , IP interfaces: 128 , IPv4 routing table entries: 1000 , IPv6 routing table entries: 512 , IPv4 forwarding table entries: 4000 , IPv6 forwarding table entries: 2000
MAC Address Table Size
32768 entries
Jumbo Frame Support
9KB
Routing Protocol
RIP-1, RIP-2, IGMPv2, IGMP, OSPFv2, PIM-SM, static IP routing, IGMPv3, OSPFv3, ECMP, RIPng, MLDv2, MLD, VRRPv2, VRRPv3, MSTP, RSTP, STP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, SSH-2, CLI, OAM, SMTP, NTP, DHCP, IPv4, IPv6
Flow control, VLAN support, DoS attack prevention, Broadcast Storm Control, High Availability, Multicast Storm Control, Unicast Storm Control, WRED, sFlow, STP support, ACL support, QoS, DAI, RSPAN, CoS, D-Link SIM, metal housing, ERPS, 6KV Surge protection, LD-VCStack, Link Aggregation, DDM, AAA, VLAN Double Tagging (Q-in-Q), Root Guard, Loop Guard, ERPS v2, flow mirroring, VLAN mirroring, WDRR, WAC, Voice VLAN, CFM, IPMB, RA guard, EEE, BPDU Filter, WRR, HOL Blocking Prevention, loopback detection, D-Link DDP, Asymmetric VLAN, Microsoft NLB, Smart Fans, DAD, DNS support, Auto Surveillance VLAN, Super VLAN
IEEE 802.1D, IEEE 802.1Q, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1v, IEEE 802.1ag, IEEE 802.3at, IEEE 802.1AX, IEEE 802.3bt
AC 100-240 V (50/60 Hz)
Power Redundancy
Optional
44 cm x 47 cm x 4.4 cm
6.54 kg
United Kingdom
Limited lifetime warranty with product registration
Enclosure Type
Rack-mountable
Subtype
Ports
PoE++
PoE Budget
740 W
Performance
32768 entries
Jumbo Frame Support
9KB
Max Units In A Stack
9
Routing Protocol
Encryption Algorithm
SSL, TLS 1.0, SSL 3.0, SSL 2.0, TLS 1.1, TLS 1.2
Authentication Method
RADIUS, TACACS+
Built-in Devices
2 x fans
Status Indicators
Power, RPS (Redundant Power Supply), USB, console, link/activity/speed, management, fan failure, stack ID
16 x 100/1000/2.5G RJ-45 PoE+ , 8 x 100/1000/2.5G/5G RJ-45 PoE++ - 60 W , 2 x 100/1000/2.5G/5G/10G RJ-45 uplink , 4 x 10Gbit/25Gbit SFP28 uplink , 1 x console RJ-45 , 1 x management (Gigabit LAN) RJ-45 , 1 x USB 2.0 Type A
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Redundancy Scheme
1+1
Power Consumption Stand by
58.3 Watt
MTBF
277,222.63 hours
FCC Class A certified, BSMI, cUL, CB, IC, VCCI Class A, RCM
United Kingdom
44 cm
47 cm
4.4 cm
6.54 kg
Limited warranty - lifetime
50 °C
10 - 90% RH
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% RH
Brand: D-Link
Price Range Ex VAT: £1500+
