D-Link 28-Port Gigabit Stackable PoE+ Smart Managed Switch with 4 x 10G SFP+ Ports
Quicklinx: J7KRWS00 Mfr#: DGS-1530-28P/B
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
POE: PoE
£786.29 ex VAT
£943.54 inc VAT
The D-Link DGS 1530-28P is a versatile switching solution designed to meet the demands of modern networking environments. With features such as support for up to 24 Gigabit Ethernet ports and Power over Ethernet (PoE) capabilities delivering 370 W, this switch facilitates efficient power distribution while ensuring high-speed data transmission. It accommodates various networking protocols, ensuring smooth operation within diverse settings.
Built for durability, the DGS 1530-28P operates effectively in a range of temperatures, from -5°C to 50°C, and is equipped with comprehensive surge protection. Additionally, it supports stackable configurations for enhanced scalability, granting the ability to manage multiple units seamlessly. The switch's robust management features, including SNMP support and traffic management capabilities, make it suitable for both small and large enterprises seeking reliability and efficiency in their networking infrastructure.
  • Durable environmental design
    The D-Link DGS 1530-28P operates within a temperature range of -5°C to 50°C, ensuring reliable performance in various conditions.
  • Flexible connectivity options
    This switch features 24 Gigabit Ethernet ports along with 4 additional 10 Gigabit SFP+ ports, providing diverse connectivity choices for different networking needs.
  • Advanced traffic management
    Support for features like IGMP snooping, VLAN trunking, and Quality of Service (QoS) help optimize network traffic, ensuring efficient resource allocation.
  • Efficient power distribution
    With Power over Ethernet (PoE) capabilities, the DGS 1530-28P can power devices while delivering high-speed data, simplifying installation and reducing cable clutter.
  • Scalable stacking capability
    Designed to be stackable, this switch can accommodate up to 9 units in a stack, allowing for easy management and expanded networking capacity.
D-Link DGS 1530-28P - switch - 24 ports - smart - rack-mountable
Switch - 24 ports - smart - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (1 PoE) + 4 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE
PoE Budget
370 W
Performance
Switching capacity: 128 Gbps , Forwarding performance (64-byte packet size): 95.24 Mpps , Stacking bandwidth: 80 Gbps
Packet buffer size: 1.5 MB , MLD groups: 1024 , VLAN groups: 4094 , Static ARP entries: 255
MAC Address Table Size
16K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
IGMP, IGMPv2, IGMPv3, MLD, MLDv2, static IP routing
Remote Management Protocol
SNMP 1, SNMP 2c, SNMP 3, RMON 1, RMON 2
ERPS, MDI, MDI-X, Link Aggregation, STP support, BPDU Filter, Loop Guard, MSTP support, RSTP, Root Guard, flow mirroring, loopback detection, port mirroring, IGMP snooping, GVRP, Private VLAN, VLAN trunking, Voice VLAN, QoS, WDRR, WRED, WRR, CoS, BPDU, DoS, EEE, D-Link DDP, NTP 3, NTP 4, LACP support, store and forward, auto-uplink (auto MDI/MDI-X), half/full duplex mode, 3 fans, 6KV Surge protection
IEEE 802.11d, IEEE 802.11p, IEEE 802.11q, IEEE 802.11s, IEEE 802.11v, IEEE 802.11w, IEEE 802.1AX, IEEE 802.3ab, IEEE 802.3ae, IEEE 802.3az, IEEE 802.3u, IEEE 802.3x, IEEE 802.3z, IEEE 802.3af, IEEE 802.3at
AC 100-240 V (50/60 Hz)
44 cm x 21 cm x 4.4 cm
3.7 kg
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
370 W
Performance
16K entries
Jumbo Frame Support
10240 bytes
Max Units In A Stack
9
Routing Protocol
Encryption Algorithm
TLS 1.2
Authentication Method
Secure Shell v.2 (SSH2), RADIUS, TACACS+
Status Indicators
Console, link/activity/speed, power, RPS (Redundant Power Supply)
24 x 1000Base-T RJ-45 , 4 x 1000Base-X SFP+ , 1 x management RJ-45 , 1 x USB 2.0 Type A
Internal power supply
MTBF
330,520 hours
BSMI, CB, cUL, EMC, FCC, IC, LVD, RCM, UKCA, VCCI, IEEE 802.3af, IEEE 802.3at
United Kingdom
44 cm
21 cm
4.4 cm
3.7 kg
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 24
Managed: Yes
POE: PoE
Brand: D-Link
Price Range Ex VAT: £750 - £1000
