D-Link 28-Port Gigabit SFP Stackable Smart Managed Switch with 4 x Combo and 4 x 10G SFP+ Ports
Quicklinx: J7KTWS00 Mfr#: DGS-1530-28SC/B
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
£742.60 ex VAT
£891.12 inc VAT
The D-Link DGS 1530-28SC is a versatile switch designed to enhance network performance and management. With a capacity that includes 1024 MLD groups and 256 VLAN groups, it offers scalability for growing networks. This switch features 28 ports, including 24 management ports and 4 10 Gigabit SFP+ ports, allowing for flexible connectivity options. Remote management capabilities support various protocols, enabling easy administration of the switch, whether via SNMP, RMON, or Telnet.
Constructed to withstand a range of environmental conditions, the DGS 1530-28SC operates within temperatures from -5°C to 50°C and can be stored in environments as low as -20°C. It boasts a capability with 1.5 MB of packet buffer size and features like Quality of Service (QoS) and flow control to ensure efficient data transmission. With its energy-efficient design and compliance with multiple standards, this switch is a choice for organizations seeking reliability and performance.
  • Robust performance
    With a switching capacity of 80 Gbps and a forwarding performance of 64 Gbps, the DGS 1530-28SC ensures swift data processing, making it suitable for high-demand environments.
  • Flexible connectivity options
    Equipped with 24 10/100/1000 ports and 4 10 Gigabit SFP+ ports, it provides options to connect devices seamlessly within a network.
  • Efficient management capabilities
    Supports multiple remote management protocols including SNMP, RMON, and SSH, allowing for easy monitoring and configuration from any location.
  • Environmental adaptability
    Operating effectively within temperatures ranging from -5°C to 50°C, and with a storage capacity suitable for extreme conditions, it is engineered for reliability in diverse settings.
  • Advanced security features
    Includes multiple encryption algorithms such as TLS and authentication methods like RADIUS to ensure secure network access and data protection.
D-Link DGS 1530-28SC - switch - 24 ports - smart - rack-mountable
Switch - 24 ports - L2+ - smart - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x Gigabit SFP + 4 x 10 Gigabit SFP+
Performance
Switching capacity: 64 Gbps , Forwarding performance (64-byte packet size): 95.24 Mpps , Stacking bandwidth: 80 Gbps
Packet buffer size: 1.5 MB , MLD groups: 1024 , VLAN groups: 4094 , Static ARP entries: 256
MAC Address Table Size
16K entries
Jumbo Frame Support
10232 bytes
Routing Protocol
IGMP, IGMPv2, IGMPv3, static IPv4 routing, static IPv6 routing, MLD, MLDv2
Remote Management Protocol
CLI, HTTP, HTTPS, NTP, RMON, SFTP, SNMP, SNMP 1, SNMP 2c, SNMP 3, SSH, Syslog, Telnet, TFTP, RMON 1, RMON 2, RMON 3, RMON 9, SSH-2, TLS, TLS 1.1, TLS 1.2
ZTP, RSPAN, ERPS, MDI, MDI-X, Link Aggregation, STP support, BPDU Filter, loopback detection, MSTP support, RSTP, Root Guard, flow control, port mirroring, ERPS v2, IGMP snooping, GVRP, Private VLAN, VLAN trunking, Voice VLAN, QoS, WDRR, WRR, CoS, BPDU, DoS, EEE, NTP server
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3ae, IEEE 802.3az, IEEE 802.3x, IEEE 802.3z, IEEE 802.1AX, IEEE 802.3ad (LACP), IEEE 802.1D, IEEE 802.1s, IEEE 802.1w, IEEE 802.1Q, IEEE 802.1v, IEEE 802.1p
AC 100-240 V (50/60 Hz)
44 cm x 21 cm x 4.4 cm
3.15 kg
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
10232 bytes
Max Units In A Stack
9
Routing Protocol
Encryption Algorithm
TLS 1.0, TLS 1.1, TLS 1.2
Authentication Method
Secure Shell v.2 (SSH2), RADIUS, TACACS+
RAM
1 GB
Flash Memory
256 MB
Status Indicators
Power, console, fan, link/activity/speed, stack
24 x 1000Base-T SFP , 4 x 1000Base-X SFP combo , 4 x 10GBase-X SFP+ , 1 x console RJ-45 , 1 x USB management
Internal power supply
Power cable disconnection prevention band, rack mount kit, rubber feet
Rack Mounting Kit
Included
RoHS, FCC, RCM, VCCI, ITU-T G.8032
United Kingdom
44 cm
21 cm
4.4 cm
3.15 kg
Limited warranty - limited lifetime warranty
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 24
Managed: Yes
Brand: D-Link
Price Range Ex VAT: £500 - £750
