D-Link 28-Port Gigabit SFP Stackable Smart Managed Switch with 4 x 10G SFP+ Ports
Quicklinx: J7KSWS00 Mfr#: DGS-1530-28S/B
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
£773.18 ex VAT
£927.81 inc VAT
The D-Link DGS 1530-28S is designed to meet the needs of modern networking, providing performance and flexibility for various environments. With a total of 24 1000Base-T Ethernet ports and 4 10 Gigabit SFP+ ports, this switch ensures high-speed connectivity and seamless communication between devices. Featuring a switching capacity of 80 Gbps and forwarding performance of 95.24 Mpps, it handles data traffic with minimal latency, making it suitable for both small and large networks.
This switch is equipped with significant management capabilities, supporting various remote management protocols including SNMP and RMON, ensuring ease of administration. With a variety of VLAN and network features, such as IGMP snooping, Quality of Service (QoS), and Link Aggregation, the DGS 1530-28S optimizes network performance and enhances security. Additionally, energy-efficient protocols help reduce power consumption while maintaining effective operations.
  • High capacity and connectivity
    With 24 1000Base-T ports and 4 10 Gigabit SFP+ ports, this switch offers extensive connectivity options, ensuring that all devices in a network can communicate efficiently.
  • Enhanced performance
    The DGS 1530-28S features a switching capacity of 80 Gbps and a forwarding performance of 95.24 Mpps, allowing fast data handling even in high-traffic scenarios.
  • Advanced management capabilities
    This switch supports a range of remote management protocols including SNMP and RMON, making network monitoring and configuration straightforward.
  • Robust security features
    Incorporating various VLAN and security features such as IGMP snooping and Quality of Service, the DGS 1530-28S helps protect data integrity and optimizes network efficiency.
  • Energy-efficient operation
    The switch includes energy-efficient Ethernet protocols, contributing to lower power consumption while maintaining high performance in networking tasks.
D-Link DGS 1530-28S - switch - 24 ports - smart - rack-mountable
Switch - 24 ports - smart - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x Gigabit SFP + 4 x 10 Gigabit SFP+ (uplink)
Performance
Switching capacity: 128 Gbps , Packet forwarding rate: 95.24 Mpps , Stacking bandwidth: 80 Gbps
IPv4 routes (static): 32 , IPv6 routes (static): 64 , VLAN groups: 4094 , IPv4 interfaces: 64 , IPv6 interfaces: 64 , Queues per port: 8 , Static MAC entries: 1024 , Units per virtual stack: 32 , Buffer capacity (MB): 1.5 , MLD groups: 1024 , Static ARP entries: 255
MAC Address Table Size
16K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
Static IP routing, IGMP, IGMPv2, IGMPv3, MLD, MLDv2, STP, RSTP, MSTP, L2PT
Remote Management Protocol
RMON 1, RMON 2, SNMP 1, SNMP 2c, SNMP 3, HTTP, Telnet, TFTP
6KV Surge protection, ZTP, ERPS, ACL support, auto-negotiation, flow control, store and forward, IPMB, High Availability, RTC, Dying Gasp, Safeguard Engine, BPDU protection, ARP spoofing, DoS, Guest VLAN, LLDP support, LLDP-MED, QoS, D-Link SIM, HOL Blocking Prevention, Link Aggregation, AAA, sFlow, D-Link DDP, loopback detection, D-Link Green Technology
IEEE 802.1ag, IEEE 802.1x, IEEE 802.3, IEEE 802.3ab, IEEE 802.3ae, IEEE 802.3u, IEEE 802.3x, IEEE 802.3ah, IEEE 802.1D, IEEE 802.1s, IEEE 802.1w, IEEE 802.1v, IEEE 802.1Q, IEEE 802.3ad (LACP), IEEE 802.3az
AC 100-240 V (50/60 Hz)
Power Redundancy
Optional
44 cm x 21 cm x 4.4 cm
3.1 kg
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
10240 bytes
Max Units In A Stack
9
Routing Protocol
Encryption Algorithm
TLS 1.2
Authentication Method
Secure Shell v.2 (SSH2), RADIUS, TACACS+
Built-in Devices
2 x smart fans
Status Indicators
Power, RPS (Redundant Power Supply), console, link/activity/speed, USB, fan failure, master, stack ID
24 x 1000Base-X SFP , 4 x 10GBase-X SFP+ , 1 x console RJ-45 , 1 x USB 2.0 Type A
Internal power supply
Power Redundancy
Optional
Power Consumption Stand by
10.5 Watt
4 rubber feet
1 x RJ-45 to RS-232 cable
Rack Mounting Kit
Included
MTBF
446,328 hours
IEC 61000-4-5, BSMI, FCC, IC, RCM, UKCA, EMC, VCCI, CB, cUL, LVD
United Kingdom
44 cm
21 cm
4.4 cm
3.1 kg
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 24
Managed: Yes
Brand: D-Link
Price Range Ex VAT: £750 - £1000
