D-Link 28-Port 2.5G Multi-Gigabit PoE++ Smart Managed Switch with 4 x 10G SFP+ Ports
Quicklinx: J7L3WS00 Mfr#: DMS-1250-28P/B
£605.27 ex VAT
£726.32 inc VAT
The D-Link DMS 1250-28P switch offers robust networking capabilities with performance features. With a total of 28 ports and PoE+ support, this switch delivers power across multiple devices while providing reliable data transmission. Its switching capacity of 200 Gbps and packet forwarding rate of 148.81 Mpps ensure efficient data handling for demanding applications.
Designed to operate in diverse environments, the D-Link DMS 1250-28P features a wide temperature range, making it suitable for various operating conditions. Enhanced with multiple management protocols, including SNMP and Telnet, network administrators can easily monitor and control the switch, while features like bandwidth control and port security enhance network performance and security. This switch is ideal for businesses seeking to enhance their networking infrastructure without compromising quality.
  • Efficient power over Ethernet support
    The D-Link DMS 1250-28P is equipped with PoE+ capabilities, allowing it to deliver power and data over existing Ethernet cables, minimizing the need for additional power sources for connected devices.
  • High performance and efficiency
    With a switching capacity of 200 Gbps and a packet forwarding rate of 148.81 Mpps, this switch ensures efficient handling of large volumes of data, making it suitable for high-traffic environments.
  • Versatile management options
    Support for multiple remote management protocols such as SNMP, RMON, and Telnet provides network administrators with flexible options for monitoring and managing the switch.
  • Robust security features
    The D-Link DMS 1250-28P incorporates security measures, including port security, Access Control Lists (ACL), and DoS attack prevention, ensuring your network remains secure from various threats.
  • Temperature resilient design
    Capable of operating in a wide temperature range of -5°C to 50°C, this switch is designed to function effectively in various environmental conditions, making it a reliable choice for different setups.
D-Link DMS 1250-28P - switch - smart
Switch - L2+ - smart
Enclosure Type
Desktop
Subtype
2.5 Gigabit Ethernet
Internal power supply
Brand: D-Link
Price Range Ex VAT: £500 - £750
