D-Link 28-Port 10G Multi-Gigabit Layer 3 Stackable PoE++ Managed Switch with 25G Uplinks
Quicklinx: J7JZWS00 Mfr#: DXS-3130-28P/B
Type: 10 Gigabit Ethernet
Ports: 28
Managed: Yes
POE: PoE++
£2,527.29 ex VAT
£3,032.74 inc VAT
The D-Link DXS 3130-28P switch is designed for high-performance networking environments that require reliable and efficient data handling. With a total of 28 ports, including 24 10/25 Gbit LAN ports and 4 SFP28 connectors, this switch offers flexible connectivity options to accommodate various network setups. The performance is supported by a switching capacity of 680 Gbps, ensuring smooth data flow and minimal latency for demanding applications.
This model features substantial routing capabilities with support for both IPv4 and IPv6 static routes. It boasts a MAC address table size of 32K entries and can manage up to 4,096 VLAN IDs, making it suitable for complex network architectures. The device operates effectively in a wide range of environmental conditions with an operating temperature range of 0°C to 50°C and a storage temperature range of -40°C to 70°C. Compliance with multiple standards ensures that it meets the required operational benchmarks, while additional features like RADIUS authentication and VLAN support enhance its security and manageability.
  • Impressive capacity
    The DXS 3130-28P is equipped to handle a significant workload with up to 1,024 IPv4 routes and 512 IPv6 routes, ensuring that it can manage extensive networking tasks seamlessly.
  • Flexible connectivity options
    With 24 10 GBase-T and 4 SFP28 ports, this switch provides versatile connectivity for various devices, accommodating different data rate requirements while ensuring compatibility with high-speed networks.
  • Advanced security features
    Equipped with advanced features such as Dynamic ARP Inspection (DAI), Access Control List (ACL) support, and port security, this switch helps in safeguarding network integrity and preventing unauthorized access.
  • Efficient power management
    The DXS 3130-28P includes D-Link Green technology, allowing for energy-efficient operations that minimize power consumption while maintaining high performance.
  • Robust management capabilities
    Support for multiple remote management protocols including SNMP, Telnet, and HTTPS ensures that the switch can be easily monitored and managed for optimal performance.
D-Link DXS 3130-28P - switch - 28 ports - Managed - rack-mountable
Switch - 28 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
24 x 1/2.5/5/10GBase-T (PoE++) + 4 x 10 Gigabit / 25 Gigabit SFP28
Power Over Ethernet (PoE)
PoE++
PoE Budget
790 W
Performance
Switching capacity: 680 Gbps , Stacking bandwidth: 200 Gbps , Packet forwarding rate: 505.92 Mpps , Forwarding rate (64-byte packets): 298 Mpps
VLAN IDs: 4094 , IPv4 routes (ARP entries): 4096 , Static ARP entries: 256 , IPv6 routes (ARP entries): 1024 , Static ARP entries: 128 , IP interfaces: 128 , Units per virtual stack: 32 , IGMP groups: 1024 , MLD groups: 1024 , Packet buffer size: 4 MB
MAC Address Table Size
32K entries
Jumbo Frame Support
12KB
Routing Protocol
Static IPv4 routing, static IPv6 routing, RIPng, OSPFv2, OSPFv3, IGMP, MLD, STP, RSTP, MSTP, IGMPv2, IGMPv3, MLDv2, PIM-SM, PPPoE, NTPv3, NTPv4, VRRPv2, VRRPv3, ECMP, RIP-1, RIP-2
Remote Management Protocol
HTTP, HTTPS, DHCP, TFTP, Telnet, DNS, SNMP 1, SNMP 2c, SNMP 3, RMON 1, RMON 2, RMON 3, RMON 9, CLI, BOOTP
6KV Surge protection, Green Technology, QoS, ERPS, loopback detection, Broadcast Storm Control, ACL support, IPMB, DHCP snooping, flow control, BPDU Filter, Root Guard, Loop Guard, port mirroring, flow mirroring, VLAN mirroring, RSPAN, ERPS v2, IGMP snooping, GVRP, WRR, WDRR, WRED, Guest VLAN, AAA, DAI, DAD, DoS attack prevention, WAC, EEE, DULD, DDM, sFlow, LLDP-MED, system log, IP source guard, Safeguard Engine, Multicast Storm Control, Unicast Storm Control, MLD snooping, bandwidth control
IEEE 802.3af, IEEE 802.3at, IEEE 802.3bt, IEEE 802.1ag, IEEE 802.1x, IEEE 802.1D, IEEE 802.1s, IEEE 802.1w, IEEE 802.3ah, ITU-T Y.1731, IEEE 802.3ad (LACP), IEEE 802.3x, IEEE 802.1AX, IEEE 802.1Q, IEEE 802.1v, IEEE 802.1p
AC 100-240 V (50/60 Hz)
Power Redundancy
44 cm x 47 cm x 4.4 cm
6.48 kg
United Kingdom
D-Link DEM-CB700S, DPS-PWR1200AC; DEM 410T, 431XT, 432XT, 433XT, 436XT-BXD, 436XT-BXU, S2801SR, S2810LR
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
PoE++
PoE Budget
790 W
Performance
32K entries
Jumbo Frame Support
12KB
Max Units In A Stack
9
Routing Protocol
Encryption Algorithm
SSL, TLS 1.0, TLS 1.1, TLS 1.2
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2), Extensible Authentication Protocol (EAP)
Built-in Devices
2 x smart fans
Status Indicators
Power, console, management, RPS (Redundant Power Supply), fan failure, USB, link/activity/speed, PoE, stack ID
24 x 100/1000/2.5G/5G/10GBase-T (PoE++) RJ-45 60 W , 4 x 10/25Gbit LAN SFP28 uplink , 1 x 10/100/1000Base-T RJ-45 console , 1 x 10/100/1000Base-T RJ-45 management , 1 x USB 2.0 Type A
Max Supported Qty
2
Power Redundancy
Power Consumption Stand by
50.18 Watt
1 x RJ-45 to RS-232 cable
Rack Mounting Kit
Included
MTBF
286,495.20 hours
IEC 61000-4-5, FCC Class A certified, VCCI Class A, IC, RCM, BSMI, CB, cUL
United Kingdom
44 cm
47 cm
4.4 cm
6.48 kg
Limited warranty - lifetime
50 °C
10 - 90% RH
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% RH
D-Link DEM-CB700S, DPS-PWR1200AC , D-Link DEM 410T, 431XT, 432XT, 433XT, 436XT-BXD, 436XT-BXU, S2801SR, S2810LR
Ports: 28
Managed: Yes
POE: PoE++
Brand: D-Link
Price Range Ex VAT: £1500+
