D-Link 28-Port 10G Multi-Gigabit Layer 3 Stackable Managed Switch
Quicklinx: J7JYWS00 Mfr#: DXS-3130-28/B
Type: 10 Gigabit Ethernet
Ports: 28
Managed: Yes
£2,429.23 ex VAT
£2,915.07 inc VAT
The D-Link DXS 3130-28 is designed to enhance network performance with robust switching capabilities and extensive management features. This switch offers a switching capacity of 680 Gbps and can process up to 505.92 million packets per second. With support for up to 28 ports, including both 10GBase-T and 10/25Gbit LAN connections, it caters to a range of networking needs. The comprehensive environmental specifications ensure reliability, with operating temperatures ranging from 0°C to 50°C and storage temperatures from -40°C to 70°C, making it suitable for various deployments. Equipped with a variety of management protocols such as SNMP and HTTPS, the D-Link DXS 3130-28 enables remote management and monitoring. It also features advanced security protocols including RADIUS, TACACS+, and Dynamic ARP Inspection (DAI), which provide an added layer of protection against unauthorized access. With supportive features like VLAN support and IGMP snooping, this switch helps streamline network traffic while managing bandwidth effectively.
  • Robust switching capabilities
    The D-Link DXS 3130-28 features a switching capacity of 680 Gbps and a forwarding rate of 505.92 million packets per second, ensuring efficient data handling and low latency in network operations.
  • Extensive port configuration
    With 28 ports including 24 10/100/1000/2.5G/5G/10GBase-T and 4 SFP28 ports, the switch provides versatile connectivity options suitable for various network setups.
  • Advanced network management
    The switch supports multiple remote management protocols including SNMP and HTTPS, allowing for monitoring and control of network performance.
  • Enhanced security features
    Incorporating authentication methods like RADIUS and TACACS+, along with Dynamic ARP Inspection and other security protocols, the D-Link DXS 3130-28 safeguards against unauthorized access and threats.
  • Suitable for diverse environments
    Designed to operate within a wide temperature range of 0°C to 50°C and support storage temperatures up to 70°C, this switch operates reliably in various settings.
D-Link DXS 3130-28 - switch - 28 ports - Managed - rack-mountable
Switch - 28 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
24 x 100/1000/2.5G/5G/10GBase-T + 4 x 10 Gigabit / 25 Gigabit SFP28
Performance
Switching capacity: 680 Gbps , Forwarding rate (64-byte packets): 505.92 Mpps , Packet buffer size: 4 MB
VLAN IDs: 4094 , IPv4 routes (ARP entries): 4096 , Static ARP entries: 256 , IPv6 routes (ARP entries): 1024 , Static ARP entries: 128 , IP interfaces: 128 , IPv4 routes (static): 512 , IPv6 routes (static): 256
MAC Address Table Size
32K entries
Jumbo Frame Support
12KB
Routing Protocol
Static IPv4 routing, static IPv6 routing
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, CLI, Telnet, TFTP, HTTP, HTTPS, RMON 1, RMON 2
ERPS, BOOTP support, DHCP client, TFTP client, SNTP support, DHCP relay, system log, ACL support, DHCP snooping, IP source guard, Safeguard Engine, DoS attack prevention, DAI, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Port Security, CoS, QoS, WDRR, WRR, ToS, MLD snooping, MSTP support, RSTP support, STP support, flow control, VLAN support, IGMP snooping, D-Link Green Technology, bandwidth control, GVRP, LLDP support, port mirroring, IP-MAC binding, DHCP server, 3 fans, 6KV Surge protection
IEEE 802.1x, IEEE 802.1Q
AC 100-240 V (50 - 60 Hz)
Power Redundancy
Optional
44 cm x 25 cm x 4.4 cm
3.525 kg
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
32K entries
Jumbo Frame Support
12KB
Max Units In A Stack
9
Routing Protocol
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
Status Indicators
25G device connected, 10G device connected, 1000M device connected, 100M device connected, 10M device connected, console, fan failure, management, RPS (Redundant Power Supply), USB
24 x 10GBase-T RJ-45 , 4 x 10/25Gbit LAN SFP28 , 1 x 10/100/1000Base-T RJ-45 console , 1 x 10/100/1000Base-T RJ-45 management , 4 x stacking , 1 x USB Type A stacking
Internal power supply
Max Supported Qty
2
Power Redundancy
Optional
Power Consumption Stand by
32.857 Watt
Redundant Power System (RPS) connector
MTBF
317,350.54 hours
BSMI, CB, cUL, FCC Class A certified, IC, RCM, VCCI Class A, AAA
United Kingdom
44 cm
25 cm
4.4 cm
3.525 kg
50 °C
10 - 90% RH
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% RH
Ports: 28
Managed: Yes
Brand: D-Link
Price Range Ex VAT: £1500+
