Efficient and resilient networking
The DGS 3000 series supports surge protection on all Ethernet ports, protecting the switch from power surges due to lightning strikes or faulty electrical cabling. -
Quality of service
The DGS 3000 series implements a rich set of multilayer QoS/CoS features to ensure that critical network services such as VoIP, video conferencing, IPTV, and IP surveillance are given high priority. Flexible packet classification can be based on various header fields or user-defined packet content to help administrators prioritize network traffic. -
Identity-driven network policies
The DGS 3000 series supports authentication mechanisms for strict access control to network resources. After authentication, individual policies such as VLAN membership, QoS policies, and ACL rules can be assigned to each host.
- D-Link DGS 3000-28LP - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 (PoE) + 4 x SFP
- Power Over Ethernet (PoE)
- PoE
- PoE Budget
- 193 W
- Performance
- Switching capacity: 56 Gbps , Forwarding performance (64-byte packet size): 68.45 Mpps
- MAC Address Table Size
- 16K entries
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, SSH
- Flow control, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), DoS attack prevention, half duplex mode, full duplex mode, Dying Gasp support, ACL support, QoS, MLD snooping, Safeguard Engine, IPv4 support, LLDP support, RSPAN, CoS, D-Link SIM, ToS, DSCP support, ERPS, 1.5MB packet buffer, ARP inspection, 6KV Surge protection, AAA, VLAN mirroring, WAC, CFM, LLDP-MED, Guest VLAN
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ae
- 44 cm x 21 cm x 4.4 cm
- 2.54 kg
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- PoE Budget
- 193 W
- Performance
- 16K entries
- Routing Protocol
- Encryption Algorithm
- SSL, SSL 3.0, SSL 2.0
- Authentication Method
- RADIUS, TACACS, TACACS+
- Status Indicators
- Power, RPS (Redundant Power Supply), fan, console, link/activity/speed
- 24 x 1000Base-T RJ-45 , 4 x SFP , 1 x console RJ-45 management
- MTBF
- 304,565 hours
- VCCI, C-Tick, BSMI, cUL, CB, FCC, IEEE 802.3af, IEEE 802.3at
- 44 cm
- 21 cm
- 4.4 cm
- 2.54 kg
- -5 °C
- 50 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
