The DGS-1100 Series is a range of powerful switches that offer a lot of bang for your buck. They are great for busy SMBs who expect a lot of their network, including support for surveillance and VoIP. They are packed with traffic management and optimization features that keep your network congestion free. Meanwhile, management tools are flexible and intuitive, making your life easier.
VLANs: stronger security and better traffic management
Relatively easy to set up, VLANs can be a big boon for your network. They can isolate sensitive areas of your network, keeping them safe from those with malicious intent, or keeping bandwidth open for latency-sensitive traffic such as VoIP. -
Actively mitigating downtime
Round-the-clock surveillance footage is vital. If you have cameras attached to your network, you may have thought technical difficulties were a given. However, the PD-Alive feature actively mitigates device downtime. If a device is not working as expected, the switch can automatically reset them and get them back online. No need to turn them on and off again in the middle of the night. -
Green technology
The DGS-1100 V2 Series is packed with environmentally and budget friendly technologies. IEEE 802.3az support automatically detects port status, lowering power to those that are unused or have no traffic passing through. Meanwhile time-based PoE further reduces consumption to ports during inactivity. Finally, fanless design allows energy-efficient operation, with the added benefit of being silent.
 - D-Link DGS 1100-24PV2 - switch - 24 ports - smart - rack-mountable
 - Switch - 24 ports - smart
- Enclosure Type
 - Rack-mountable 1U
- Subtype
 - Gigabit Ethernet
- Ports
 - 24 x 10/100/1000 (12 PoE)
- Power Over Ethernet (PoE)
 - PoE
- PoE Budget
 - 100 W
- Performance
 - Switching capacity: 48 Gbps , Forwarding performance: 35.71 Mpps
- Capacity
 - VLAN groups: 128 , VLAN IDs: 4094 , IGMP groups: 128
- MAC Address Table Size
 - 8K entries
- Jumbo Frame Support
 - 10240 bytes
- Routing Protocol
 - IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
 - SNMP 2, ICMP
 - Flow control, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, QoS, Cable Diagnostics Function, bandwidth control, fanless, LLDP support, Port Security, DHCP client, 512KB packet buffer, tagged VLAN, DSCP support, IGMP querier, Voice VLAN, VLAN management, VLAN group, EEE, WRR, HOL Blocking Prevention, loopback detection, port-based VLAN, port-based QoS, Unknown Storm Control, DNA support, Asymmetric VLAN
 - IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
- Power
 - AC 120/230 V (50/60 Hz)
 - 28 cm x 23 cm x 4.4 cm
 - 2 kg
- Enclosure Type
 - Desktop, rack-mountable 1U
- Subtype
 - Gigabit Ethernet
- Ports
 - PoE
- PoE Budget
 - 100 W
- Performance
- Capacity
 - 8K entries
 - 10240 bytes
- Routing Protocol
 - SNMP 2, ICMP
- Encryption Algorithm
 - SSL
- Processor
 - : 500 MHz
- RAM
 - 128 MB
- Flash Memory
 - 16 MB
- Status Indicators
 - Power, status, PoE, link/activity/speed
 - 24 x 1000Base-T RJ-45 12 ports (PoE)
- Power Device
 - Internal power supply
- Voltage Required
 - 19.5 Watt
- Power Consumption Stand by
 - 8.8 Watt
- Included Accessories
 - 4 rubber feet, 2 x 19" mounting brackets
- Rack Mounting Kit
 - Included
- MTBF
 - 255,003 hours
 - FCC Class A certified, C-Tick, BSMI, cUL, CB, CCC, RoHS, LVD, VCCI Class A
- Software Included
 - D-Link Network Assistant
 - 28 cm
 - 23 cm
 - 4.4 cm
 - 2 kg
 - -5 °C
 - 50 °C
 - 0 - 95% (non-condensing)
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
