D-Link 24-Port PoE Gigabit Smart Managed Switch
Quicklinx: J7KLWS00 Mfr#: DGS-1100-24PV2
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
POE: PoE
£148.40 ex VAT
£178.08 inc VAT
The DGS-1100 Series is a range of powerful switches that offer a lot of bang for your buck. They are great for busy SMBs who expect a lot of their network, including support for surveillance and VoIP. They are packed with traffic management and optimization features that keep your network congestion free. Meanwhile, management tools are flexible and intuitive, making your life easier.
  • VLANs: stronger security and better traffic management
    Relatively easy to set up, VLANs can be a big boon for your network. They can isolate sensitive areas of your network, keeping them safe from those with malicious intent, or keeping bandwidth open for latency-sensitive traffic such as VoIP.
  • Actively mitigating downtime
    Round-the-clock surveillance footage is vital. If you have cameras attached to your network, you may have thought technical difficulties were a given. However, the PD-Alive feature actively mitigates device downtime. If a device is not working as expected, the switch can automatically reset them and get them back online. No need to turn them on and off again in the middle of the night.
  • Green technology
    The DGS-1100 V2 Series is packed with environmentally and budget friendly technologies. IEEE 802.3az support automatically detects port status, lowering power to those that are unused or have no traffic passing through. Meanwhile time-based PoE further reduces consumption to ports during inactivity. Finally, fanless design allows energy-efficient operation, with the added benefit of being silent.
D-Link DGS 1100-24PV2 - switch - 24 ports - smart - rack-mountable
Switch - 24 ports - smart
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (12 PoE)
Power Over Ethernet (PoE)
PoE
PoE Budget
100 W
Performance
Switching capacity: 48 Gbps , Forwarding performance: 35.71 Mpps
VLAN groups: 128 , VLAN IDs: 4094 , IGMP groups: 128
MAC Address Table Size
8K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 2, ICMP
Flow control, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, QoS, Cable Diagnostics Function, bandwidth control, fanless, LLDP support, Port Security, DHCP client, 512KB packet buffer, tagged VLAN, DSCP support, IGMP querier, Voice VLAN, VLAN management, VLAN group, EEE, WRR, HOL Blocking Prevention, loopback detection, port-based VLAN, port-based QoS, Unknown Storm Control, DNA support, Asymmetric VLAN
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
28 cm x 23 cm x 4.4 cm
2 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
100 W
Performance
8K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
SNMP 2, ICMP
Encryption Algorithm
SSL
: 500 MHz
RAM
128 MB
Flash Memory
16 MB
Status Indicators
Power, status, PoE, link/activity/speed
24 x 1000Base-T RJ-45 12 ports (PoE)
Internal power supply
19.5 watt
Power Consumption Stand by
8.8 watt
4 rubber feet, 2 x 19" mounting brackets
Rack Mounting Kit
Included
MTBF
255,003 hours
FCC Class A certified, C-Tick, BSMI, cUL, CB, CCC, RoHS, LVD, VCCI Class A
Software Included
D-Link Network Assistant
28 cm
23 cm
4.4 cm
2 kg
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 24
Managed: Yes
POE: PoE
Brand: D-Link
