The DGS-1100 Series is a range of switches designed to meet the requirements of small, medium, and enterprise businesses. Support for multiple PoE standards make the DGS-1100 Series ideal for IP surveillance deployments. Advanced management features, a range of diagnostic and troubleshooting tools, and energy-efficient technologies provide a flexible solution to meet your networking requirements.
Gigabit Ethernet speed
High-speed ports provide the Ethernet technology while retaining backward compatibility for connections to older computers and equipment. -
Revolutionary energy efficiency
Innovative D-Link Green features help conserve energy without sacrificing performance so you can reduce operating costs and protect the environment. -
Smart and flexible management
Powerful switch management functions can be performed through the web management interface or through a client-based utility. -
Surveillance VLAN and bandwidth control
Supports Surveillance VLAN for IP surveillance deployments. This gives video traffic a dedicated VLAN and higher priority through the switch, separating surveillance traffic from the rest of the network. -
Advanced features
The switch is equipped with advanced security features such as Static MAC, Storm Control, and IGMP Snooping. -
Easy troubleshooting
Features Loopback Detection and Cable Diagnostics to help network administrators find and solve network problems quickly and easily.
- D-Link DGS 1100-24V2 - switch - 24 ports - smart - rack-mountable
- Switch - 24 ports - smart
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000
- Performance
- Switching capacity: 48 Gbps , Forwarding performance: 35.71 Mpps
- Capacity
- VLAN groups: 128 , VLAN IDs: 4094 , IGMP groups: 128
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 10000 bytes
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
- SNMP 2, ICMP
- Flow control, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, QoS, Cable Diagnostics Function, bandwidth control, fanless, LLDP support, Port Security, DHCP client, tagged VLAN, DSCP support, 4.1MB packet buffer, IGMP querier, Voice VLAN, VLAN management, VLAN group, EEE, WRR, HOL Blocking Prevention, loopback detection, port-based VLAN, port-based QoS, Unknown Storm Control, DNA support, Asymmetric VLAN
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1ab (LLDP), IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 28 cm x 18 cm x 4.4 cm
- 1.32 kg
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000
- Performance
- Capacity
- 8K entries
- 10000 bytes
- Routing Protocol
- SNMP 2, ICMP
- Encryption Algorithm
- SSL
- Flash Memory
- 16 MB
- Status Indicators
- Status
- 24 x 1000Base-T RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 15.9 Watt
- Power Consumption Stand by
- 4.5 Watt
- Rack Mounting Kit
- Included
- MTBF
- 424,762 hours
- FCC Class A certified, C-Tick, BSMI, cUL, CB, CCC, RoHS, LVD, VCCI Class A
- Software Included
- D-Link Network Assistant
- 28 cm
- 18 cm
- 4.4 cm
- 1.32 kg
- -5 °C
- 50 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
