D-Link 24-Port Gigabit Smart+ Switch including 4 SFP ports
THIRD GENERATION DESIGN, IMPROVED MANAGEMENT AND SECURITY FUNCTION
Quicklinx: 93C3WS00 Mfr#: DGS-1210-28P
Type: Gigabit Ethernet
Ports: 24
Data Transfer Rate: 1Gbps
Managed: Yes
POE: PoE
More than 50 In Stock
£236.44 ex VAT
£283.72 inc VAT
This D-link DGS-1210-28P is part of D-Link's 3rd generation of Web Smart Switches that integrates advanced management and security functions for performance and scalability. With D-link Green technology now in its second generation, this D-Link DGS-1210-28P provides a complete, affordable and eco-friendly solution for small and medium businesses (SMB).
Power over Ethernet (PoE) support
This D-Link DGS-1210-28P features 24 PoE ports. They provide either up to 30W on 4 ports, 15.4W on 12 ports or 7.5W on 24 ports. This gives administrators the flexibility to connect 802.3af compliant devices such as network cameras and IP phones, as well as 802.3at pre-standard equipment such as 802.11n Access Points. Uniquely, the PoE function is programmable, so power can be cut at certain times to save energy.
Seamless Integration
This D-Link DGS-1210-28P includes 24 10/100/1000 Mbps ports capable of connecting to existing Cat.5 twisted-pair cables and the last four ports of this D-Link DGS-1210-28P combine SFP and copper connectivity into one port to provide a flexible solution for server connections via fiber interface. Using the default presets, the administrator can quickly set up the switch without worrying about reconfiguring any settings and providing easy access for the user.
Extensive Layer 2 Features
Equipped with a complete lineup of L2 features, these switches include IGMP Snooping, Port Mirroring, Spanning Tree and Link Aggregation Control Protocol (LACP). The IEEE 802.3x Flow Control function allows servers to directly connect to this D-Link DGS-1210-28P switch for fast, reliable data transfer. At 2000 Mbps Full Duplex, the Gigabit ports provide high-speed data pipes to servers with minimum data transfer loss. Network maintenance features include Loopback Detection and Cable Diagnostics. Loopback Detection is used to detect loops created by a specific port and automatically shut down the affected port. Cable Diagnostics is designed for network administrators to quickly examine the quality of the copper cables and also determine the type of cable error.
QoS & bandwidth control
This D-Link DGS-1210-28P switch is perfect for deployment in a VoIP environment, as it supports Auto Voice VLAN and Differentiated Services Code Point (DSCP) QoS for VoIP application. Auto Voice VLAN will automatically place voice traffic from an IP phone to an assigned VLAN and by doing so enhance the VoIP service. With a higher priority and individual VLAN, this feature guarantees the quality and security of VoIP traffic. DSCP marks parts of an IP packet, enabling different levels of service to be assigned for network traffic.
Secure your Network
D-Link's unique Safeguard Engine function protects the switch against traffic flooding caused by virus attacks. This D-Link DGS-1210-28P switch also supports 802.1X port-based authentication, allowing the network to be authenticated through an external RADIUS server. In addition, the Access Control List (ACL) feature enhances network security and helps to protect the internal IT network.
This D-link DGS-1210-28P includes ARP Spoofing Prevention, which protects from attacks on the Ethernet network that may allow an intruder to sniff data frames on a LAN, modify traffic, or bring traffic to a halt altogether by sending fake ARP messages to the network. To prevent ARP Spoofing attacks, the switch uses Packet Control ACLs to block invalid packets that contain fake ARP messages.
Versatile Management
This D-Link DGS-1210-28P provides a SmartConsole utility and a web-based management interface that enables administrators to remotely control their network down to the port level. The SmartConsole easily allows customers to discover multiple D-Link Web Smart Switches within the same L2 network segment. With this utility, users do not need to change the IP address of their PC and it also provides an easy initial setting of the Smart Switches. Switches within the same L2 network segment that are connected to the user's PC are displayed on screen for instant access.
This allows extensive switch configuration settings and basic configuration of discovered devices such as password changes and firmware upgrades. This D-Link DGS-1210-28P also supports D-View 6.0, D-Link's own Network Management System, and Compact Command Line Interface (CLI) through Telnet. CLI management of the switches is possible via Telnet. This makes the adjustment of basic settings like password changes or firmware and configuration file uploads possible.
D-Link Green
This D-Link DGS-1210-28P implements D-Link Green, an innovative concept that provides energy savings whitout sacrificing operational performance or functionality. D-Links switch reacts when devices attached to it are turned off, by placing the corresponding port in a standby mode that requires less power. It also automatically detects the length of connected cables, which allows it to cut power usage on shorter cable connections up to 20 m.
D-Link Green certification ensures that the switch complies with the RoHS (Restriction of Hazardous Substances) and WEEE (Waste Electrical and Electronic Equipment) directives. RoHS restrict the use of specific hazardous materials during the manufacture of electrical and electronic goods, while WEEE applies standards for proper disposal and recyclable packaging to help reduce wastage.
Standard Warranty: Limited Lifetime
Key Features
  • Third generation design, with improved management and security functions
  • Power-saving D-Link Green technology now in its 2nd generation
  • Solid security with 802.1X authentication and IP/MAC based Access Control Lists (ACL)
  • Malicious traffic and performance degradation prevention with D-Link Safeguard Engine
  • Auto Voice VLAN for the automatic prioritisation of digital voice traffic
  • Quality of service (QoS) and bandwidth control (down to 64 kbps)
  • High Reliability with Loopback Detection (LBD) and cable diagnostics
  • Simple Web based management
  • SmartConsole utility for the joint management of several switches
  • Discovery and notification
    D-Link Insight will track all the devices connected to the smart switch and list them by MAC, IP and switch port. Insight also provides alerts to notify you when more devices are found on the network. Each client device's operating system can also be fingerprinted.
  • Configuration management
    Simple, automated configuration management creates a backup of the switch settings for easy restore. Return to the last known state or bring a device online without cumbersome configuration.
  • Alerts
    Always know the status of your network through Insight alerting. Should one of your web smart switches go offline or reboot, you're immediately notified. No more guessing or waiting for an outage report. Configure smart list alerts to inform you when unexpected computers are discovered on the network.
  • Active compliance monitoring with insight plus
    Windows and Mac OS clients are screened by D-Link Insight Plus, which acts as an active security sentry to validate compliance to policies on a client's operating system patch level, firewall, antivirus and anti-spyware. Reports and alerts provide you with the data you need to properly determine status and access privileges.
D-Link Web Smart DGS-1210-28P - switch - 24 ports - Managed - desktop, rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE) + 4 x Gigabit SFP
Power Over Ethernet (PoE)
PoE
Performance
Switching capacity : 56 Gbps , Forwarding performance : 41.7 Mpps
MAC Address Table Size
16K entries
Jumbo Frame Support
10000 bytes
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
Flow control, full duplex capability, Layer 2 switching, power over Ethernet (PoE), auto-negotiation, BOOTP support, RARP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, MAC address filtering, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Safeguard Engine, D-Link Green Technology
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3at
AC 120/230 V ( 50/60 Hz )
Enclosure Type
Desktop, rack-mountable - 1U
Subtype
Gigabit Ethernet
Ports
PoE
Performance
16K entries
Jumbo Frame Support
10000 bytes
RAM
128 MB
Flash Memory
16 MB
Status Indicators
Link activity, port transmission speed, power, link OK
24 x 1000Base-T - RJ-45 - PoE , 4 x SFP (mini-GBIC)
Internal power supply
FCC Class A certified, C-Tick, cUL, VCCI Class A ITE, IC Class A
50 °C
0 - 95%
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95%
93C3 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.73
93C3 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.64
Ports: 24
Managed: Yes
POE: PoE
Brand: D-Link
