The D-Link DGS-1026MP 26-Port Gigabit Max PoE Switch enables users to easily connect and power PoE-capable devices such as wireless access points (APs), IP cameras, and IP phones. Each of the 24 PoE ports can supply up to 30 W, with a total PoE budget of 370 W.
Power over Ethernet
The DGS-1026MP features 24 10/100/1000Base-T ports, that support the IEEE 802.3at PoE+ standard. Each of the 24 PoE ports can supply optimal power, with a high total PoE budget. The PoE usage LEDs further provide real-time feedback on the current PoE power usage on the network and help plan out the PoE network budget, preventing PoE overloading problems. -
Expand your network
The addition of two Gigabit combo uplink ports means businesses can increase their network bandwidth, using the speed of Gigabit Ethernet, while offering redundancy, so voice and surveillance data are transferred reliably. -
Energy efficient
To help small businesses save on operating costs, the DGS-1026MP supports IEEE 802.3az Energy Efficient Ethernet (EEE). This feature actively monitors network traffic and automatically puts ports, that are not being used into hibernation, powering them on, only when they are required. -
Hassle-free setup
The DGS-1026MP is a Plug and Play device, that requires no configuration, so setup is simple and hassle-free. Simply connect the switch to the network and then connect multiple computers, share files and make VoIP calls across the network.
 - D-Link DGS 1026MP - switch - 26 ports - unmanaged - rack-mountable
 - Switch - 26 ports - unmanaged
- Enclosure Type
 - Rack-mountable 1U
- Subtype
 - Gigabit Ethernet
- Ports
 - 24 x 10/100/1000 (PoE) + 2 x combo Gigabit SFP
- Power Over Ethernet (PoE)
 - PoE
- PoE Budget
 - 370 W
- Performance
 - Switching capacity: 52 Gbps , Forwarding performance (64-byte packet size): 38.69 Mpps
- MAC Address Table Size
 - 8K entries
 - Flow control, auto-uplink (auto MDI/MDI-X), store and forward, Energy Efficient Ethernet
 - IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
- Power
 - AC 120/230 V (50/60 Hz)
 - 25.04 cm x 44 cm x 4.4 cm
 - 3.1 kg
- Enclosure Type
 - Desktop, rack-mountable 1U
- Subtype
 - Gigabit Ethernet
- Ports
 - PoE
- PoE Budget
 - 370 W
- Performance
 - 8K entries
- Status Indicators
 - Port transmission speed, power, fail, PoE, link/activity
 - 24 x 1000Base-T RJ-45 PoE - 30 W , 2 x 1000Base-T RJ-45 , 2 x Gigabit LAN SFP
- Power Device
 - Internal power supply
- Voltage Required
- Rack Mounting Kit
 - Included
- MTBF
 - 205,975 hours
 - FCC Class A certified, VCCI, BSMI, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, RCM
 - 25.04 cm
 - 44 cm
 - 4.4 cm
 - 3.1 kg
 - 0 °C
 - 50 °C
 - 10 - 90% (non-condensing)
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
 - 5 - 95% (non-condensing)
