The D-Link DXS-1210 Series 10 Gigabit Ethernet smart managed switches are cost-effective and capable of servicing a range of network needs in any business. Supporting 10GBASE-T/SFP+ combo ports, this series provides connection flexibility across a network allowing for easier network integration. With high performance and low latency, the DXS-1210 Series fulfills the needs for virtualization, cloud services, and server-to-server applications, making it perfect for small to medium business (SMB) customers.
                Affordable 10G capabilities for a reliable high-speed networkAdd 10-Gigabit Ethernet connectivity to your network with these cost-effective switches. Designed to work as the network core for small to medium businesses (SMBs) or as an aggregation switch in a larger enterprise.
                Extensive Layer 2 and Layer 3 Lite featuresThe DXS-1210 series includes Layer 2 features such as port mirroring, Spanning Tree Protocol (STP), and Link Aggregation Control Protocol (LACP). They also support IP interfaces, ARP, IPv6 Neighbor Discovery (ND), default routing, IPv4/IPv6 static routing, IGMP and MLD Snooping, Auto Surveillance VLAN and Auto Voice VLAN, LLDP and LLDP-MED.
                Improved intranet performanceInter-VLAN routing allows traffic to be routed between VLANs without passing through the router, reducing the load on the router as well as the backbone networks.
                Security and QoS controls for prioritiesSecurity controls for protection of the network, and QoS ensures essential traffic reaches its destination.
                Versatile network management optionsThe DXS-1210 Series comes with the D-Link Network Assistant (DNA) utility which simplifies the discovery of devices using the D-Link Discovery Protocol within the same L2 network segment and displays them on screen for instant access. Simultaneous configurations and basic setups of all discovered devices, including password changes and firmware upgrades, can then be done easily. The DXS-1210 Series also supports a full Telnet Command Line Interface (CLI) and D-View 7 - a network management system (NMS) that allows for central management of critical network characteristics such as availability, reliability, resilience, and security.
                Seamless integrationThe DXS-1210 Series comes with both RJ45 and SFP+ ports capable of connecting to Cat 6 and fiber for 10G Ethernet. Additionally, the DXS-1210-28T comes with 4 x 10/25G SFP28 ports. This means the DXS-1210 series can provide a flexible solution for upstream or downstream server connections, making network deployment easier.
                Security with every portThe innovative D-Link Safeguard Engine protects the switches against traffic flooding caused by malicious attacks and increases overall network reliability. These switches also feature Address Resolution Protocol (ARP) spoofing prevention which further protects the network from cyberattacks. They also use packet control ACLs to block invalid packets that contain fake ARP messages. The Access Control List (ACL) helps protect the internal IT network through permission-based network access. The DHCP server screen feature filters DHCP replies on unauthorized ports to prevent them from being assigned an IP address. And support for 802.1X port-based and host-based authentication allows the network to be authenticated through external RADIUS servers.
                QoS and bandwidth control for network prioritiesThe DXS-1210 Series supports Auto Surveillance VLAN (ASV) and Auto Voice VLAN, to make faster VoIP and video surveillance deployments.
                Energy-efficient without sacrificesWith D-Link Green technology included, it saves power without any loss of operational performance or functionality.
                Auto-adjusting fans with heat sensorsBuilt-in smart fans with internal heat sensors monitor and detect temperature changes and react by utilizing different fan speeds to keep systems at optimal temperature.
                Sleep modeLink status drastically reduces power consumption by automatically putting ports without a link into sleep mode.
                Advanced chipsetUtilizes silicon technology to make energy use more efficient.
- D-Link DXS 1210-28T - switch - 28 ports - smart - rack-mountable
- Switch - 28 ports - smart
- Enclosure Type
- Rack-mountable
- Subtype
- 10 Gigabit Ethernet
- Ports
- 24 x 10GBase-T + 4 x 25 Gigabit SFP28
- Performance
- Switching capacity: 680 Mbps , Forwarding performance: 505.92 Mpps
- Capacity
- VLAN IDs: 4094 , IPv4 routes (static): 128 , IPv6 routes (static): 64 , Static ARP entries: 384
- MAC Address Table Size
- 32000 entries
- Jumbo Frame Support
- 12288 bytes
- Routing Protocol
- Static IPv4 routing, static IPv6 routing
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, CLI
- Flow control, BOOTP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, WRR queuing, store and forward, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, SNTP support, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, DHCP server, MLD snooping, DAI, Safeguard Engine, Cable Diagnostics Function, bandwidth control, D-Link Green Technology, DWRR, LLDP support, DHCP relay, Port Security, IP-MAC binding, port based access control, DHCP client, GVRP, static routing, CoS, TFTP client, 4MB packet buffer, ToS, ERPS, system log, IP source guard, DRR, host based access control, Smart Fans
- IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.3p, IEEE 802.3an, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 44.1 cm x 20.95 cm x 4.4 cm
- 3.07 kg
- Enclosure Type
- Rack-mountable
- Subtype
- Ports
- Performance
- Capacity
- 32000 entries
- 12288 bytes
- Routing Protocol
- Encryption Algorithm
- TLS 1.0, PEAP, TTLS, TLS 1.1, TLS 1.2
- Authentication Method
- RADIUS, Secure Shell v.2 (SSH2), Extensible Authentication Protocol (EAP)
- Processor
- X ARM Cortex-A9 + Cortex-R5
- RAM
- 256 MB
- Flash Memory
- 64 MB
- Status Indicators
- Power, fan, link/activity/speed
- 24 x 10GBase-T RJ-45 , 4 x 25GBase-X SFP28 , 1 x console RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 90 Watt
- Power Consumption Stand by
- 33 Watt
- Included Accessories
- 4 rubber feet, 2 x 19" mounting brackets
- Cables Included
- 1 x console cable
- Rack Mounting Kit
- Included
- MTBF
- 572 820 hours
- FCC Class A certified, UL, BSMI, CB, IC, VCCI Class A
- 44.1 cm
- 20.95 cm
- 4.4 cm
- 3.07 kg
- -5 °C
- 50 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
