The D-Link DXS-1210-28S 10 Gigabit Ethernet smart managed switch is a cost-effective capable for a range of network needs in any business environment. Supporting a combination of 10GBase-T and SFP ports, this switch provides connection flexibility across a network allowing for easier network integration. With high performance and low latency, the DXS-1210-28S fulfills the needs for virtualization, cloud services, and server-to-server applications.
Extensive management and Layer 2 features
The DXS-1210-28S comes with a complete lineup of L2 features, including port mirroring, Spanning Tree Protocol (STP), and Link Aggregation Control Protocol (LACP). Network maintenance features include loopback detection and cable diagnostics. Loopback detection significantly speeds up troubleshooting by automatically detecting and shutting down difficult to diagnose switching loops. The cable diagnostic feature, designed primarily for administrators and customer service representatives, determines the cable quality and quickly discovers errors, allowing hassle-free diagnostics and maintenance. -
Quality of service and bandwidth control
The DXS-1210-28S supports Auto Surveillance VLAN (ASV) and Auto Voice VLAN, which are best suited for VoIP and video surveillance deployments. Auto Surveillance VLAN is the advanced technology that consolidates data and surveillance video transmission through a single DXS-1210-28S switch, sparing businesses the expense of dedicated hardware and facilities. ASV also ensures quality real-time video monitoring and control without compromising the transmission of conventional network data. Auto Voice VLAN technology enhances the VoIP service by automatically placing voice traffic from IP phones to a designated VLAN. With higher priority and an individual VLAN, these features guarantee the quality and security of VoIP traffic. The Differentiated Service Code Point (DSCP) markings on Ethernet packets enable different levels of service to be assigned to network traffic. As a result, these voice and video packets take precedence over other packets. In addition, with bandwidth control, network administrators can reserve bandwidth for important functions that require higher priority or more bandwidth. -
Versatile management
The DXS-1210-28S comes with the D-Link Network Assistant (DNA) utility that simplifies the configuration of devices that support the D-Link Discovery Protocol. The D-Link Network Assistant utility easily allows customers to discover multiple D-Link smart switches within the same L2 network segment and displays them on screen for instant access. With this utility, users do not need to change the IP address of their PC. This utility further allows for simultaneous configuration and basic setup of all discovered devices, including password changes and firmware upgrades. The DXS-1210-28S also supports a comprehensive 10-language multilingual web UI, a full command line interface (CLI) through Telnet, a console port, as well as D-View 7; a network management system (NMS) that allows for central management of critical network characteristics such as availability, reliability, resilience, and security. -
Secure your network
D-Link's innovative Safeguard Engine protects the switch against traffic flooding caused by malicious attacks. The DXS-1210-28S supports 802.1X port-based and host-based authentication, allowing the network to be authenticated through external RADIUS servers. The Access Control List (ACL) feature enhances network security and helps to protect the internal IT network. For added security, the DHCP server screening feature filters DHCP replies on unauthorized ports to prevent them from being assigned an IP address.
- D-Link DXS 1210-28S - switch - 28 ports - smart - rack-mountable
- Switch - 28 ports - smart
- Enclosure Type
- Rack-mountable
- Subtype
- 10 Gigabit Ethernet
- Ports
- 24 x 10GBase-X + 4 x 10Gb Ethernet
- Performance
- Switching capacity: 560 Gbps , Forwarding performance: 416,64 Mpps
- Capacity
- VLAN IDs: 4094 , IPv4 routes (static): 128 , IPv6 routes (static): 64 , Static ARP entries: 384
- MAC Address Table Size
- 32000 entries
- Jumbo Frame Support
- 12288 bytes
- Routing Protocol
- Static IPv4 routing, static IPv6 routing
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, CLI
- Flow control, BOOTP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, WRR queuing, store and forward, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, SNTP support, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, DHCP server, MLD snooping, DAI, Safeguard Engine, Cable Diagnostics Function, bandwidth control, D-Link Green Technology, DWRR, LLDP support, DHCP relay, Port Security, IP-MAC binding, port based access control, DHCP client, GVRP, static routing, CoS, TFTP client, 4MB packet buffer, ToS, ERPS, system log, IP source guard, DRR, host based access control, Smart Fans
- IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.3p, IEEE 802.3an, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 44.1 cm x 20.95 cm x 4.4 cm
- 3.27 kg
- Enclosure Type
- Rack-mountable
- Subtype
- Ports
- Performance
- Capacity
- 32000 entries
- 12288 bytes
- Routing Protocol
- Encryption Algorithm
- TLS 1.0, PEAP, TTLS, TLS 1.1, TLS 1.2
- Authentication Method
- RADIUS, Secure Shell v.2 (SSH2), Extensible Authentication Protocol (EAP)
- Processor
- X ARM Cortex-A9 + Cortex-R5
- RAM
- 256 MB
- Flash Memory
- 64 MB
- Status Indicators
- Power, fan, link/activity/speed
- 24 x 10GBase-X SFP+ , 4 x 10GBase-T RJ-45 , 1 x console RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 87.7 Watt
- Power Consumption Stand by
- 27.6 Watt
- Included Accessories
- 4 rubber feet, 2 x 19" mounting brackets
- Cables Included
- 1 x console cable
- Rack Mounting Kit
- Included
- MTBF
- 574 720 hours
- FCC Class A certified, UL, BSMI, CB, IC, VCCI Class A
- 44.1 cm
- 20.95 cm
- 4.4 cm
- 3.27 kg
- -5 °C
- 50 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
