D-Link 24-Port 10/100Mbps Nway Switch
Customer rating: 5.0* (Write a review)
Quicklinx: 2D7HWS00 Mfr#: DES-1024D/B
Type: Fast Ethernet
Ports: 24
Data Transfer Rate: 100Mbps
Managed: No
POE: [N/A]
£43.49 ex VAT
£52.18 inc VAT
This desktop switch is designed for small offices and larger workgroups.
All ports auto-sense the network speed of the computers and hubs to run at either 10Mbps or 100Mbps. The ports also auto-negotiate between full and half duplex and support flow control. Expansion is easy through a MDI uplink port. You cascade several switches together through this port to get more ports.
IEEE 802.3x Flow Control allows your servers to directly connect to this switch for fast, reliable data transfer.
D-Link DES 1024D - switch - 24 ports - unmanaged - rack-mountable
Switch - 24 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
24 x 10/100
Performance
Switching fabric bandwidth: 4.8 Gbps
MAC Address Table Size
8K entries
Flow control, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, QoS, Energy Efficient Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
28 cm x 12.58 cm x 4.4 cm
Enclosure Type
Desktop, rack-mountable
Subtype
Fast Ethernet
Ports
24 x 10/100
Performance
8K entries
Status Indicators
Power, link/activity
24 x 100Base-TX RJ-45
Internal power supply
FCC Class A certified, cUL, ICES-003 Class A, C-Tick Class A, LVD, VCCI Class A
28 cm
12.58 cm
4.4 cm
10 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Customer reviews
Write a review for the D-Link 24-Port 10/100Mbps Nway Switch here!
Just like Ronseal - Does exactly what it says on the tin
Reviewed by Martyn Talbot. Review Posted 24/07/2006
Ordered. Delivered. Installed. Works. All screws and fittings required for fitment to a 19" rack were in the box. Installation (including screwing) took less than 5 minutes with an immediate improvement in network performance. Functional, cheap and a 5yr guarantee - who could ask for more.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Type: Fast Ethernet
Ports: 24
Managed: No
POE: [N/A]
Brand: D-Link
