D-Link 24-PORT 10/100 EASYSMART SWITC
Quicklinx: 7GQYWS00 Mfr#: DES-1100-24
Type: Fast Ethernet
Ports: 24
Data Transfer Rate: 100Mbps
Managed: Yes
POE: No
Hurry, only 1 left in stock!
£57.69 ex VAT
£69.22 inc VAT
The DES-1100 Series Fast Ethernet Smart Managed Switch features a full set of configurable functions that provide strong performance and scalability. With an easy-to-use management interface accessible via a PC utility or web browser, the DES-1100 Series helps customers to quickly and easily deploy their network.
  • Resilience and performance
    The basic lineup of L2 features in the EasySmart series makes them very suitable for SMB with small IT teams, without sacrificing on performance and security. Network downtime is reduced drastically with loopback detection and broadcast storm control. Security and confidentiality of network traffic is guaranteed with VLANs. Ample bandwidth on the uplinks to the rest of the network can be achieved with link aggregation, and the cable diagnostics function provides an easy and convenient way to quickly detect and troubleshoot cabling problems.
  • Versatile management
    The EasySmart series can be easily configured through an intuitive, password-protected web-based interface or a PC-based Smart Console Utility. The web interface allows network administrators to remotely control and monitor the switch down to the port level. The SmartConsole utility is a very convenient way to set up a number of EasySmart switches in the same network segment. The SmartConsole utility will automatically discover all available switches and provide instant access, so network deployments can be completed easily and effectively.
D-Link EasySmart Switch DES-1100-24 - switch - 24 ports - Managed
Switch - 24 ports - Managed
Enclosure Type
1U
Subtype
Fast Ethernet
Ports
24 x 10/100
MAC Address Table Size
8K entries
Remote Management Protocol
HTTP
Flow control, auto-negotiation, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, Quality of Service (QoS), bandwidth control
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x
28 cm x 12.5 cm x 4.4 cm
227 g
Enclosure Type
Desktop 1U
Subtype
Fast Ethernet
Ports
24 x 10/100
8K entries
HTTP
Flash Memory
1 MB
Status Indicators
Port transmission speed, power, link OK, link/activity
24 x 100Base-TX RJ-45
Internal power supply
7.68 Watt
Mounting Kit
Included
MTBF
562,066 hours
FCC Class A certified, UL, C-Tick, cUL, VCCI Class A ITE, IC
28 cm
12.5 cm
4.4 cm
227 g
10 - 95%
7GQY C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
7GQY C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.24
7GQY C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.07
7GQY C2G 2m Cat6a Shielded Patch - Blue In Stock £7.44
Type: Fast Ethernet
Ports: 24
Managed: Yes
POE: No
Brand: D-Link
Price Range Ex VAT: 50 - 100
