The DWS-3160 Series is D-Link's latest unified wired/wireless Gigabit Layer 2+ managed switch. Designed to be the ideal mobility solution for medium-sized and large enterprises and service providers, the DWS-3160 empowers administrators to exercise total control over their wireless networks by centralizing all aspects of provisioning and management.
Simplified management
The DWS-3160 is able to centralize all critical WLAN management, thereby eliminating the need to manage access points individually. The administrator simply assigns a profile to an individual D-Link Unified Access Point, and the configuration corresponding to that profile would be applied onto that access point automatically. -
Trusted security
The DWS-3160 offers a state-of-the-art Wireless Intrusion Detection System (WIDS), which empowers administrators to detect Rogue Access Points and Rogue Clients, effectively preventing them from causing damage to the network. The administrator can also activate various threat detections and use Radio Frequency Scan to sweep the entire wireless network to identify any possible security breach in advance. -
Network resiliency
When a number of access points are deployed close to each other, interference may result if proper RF management is not implemented. The DWS-3160 is aware of how the radio spectrum is being utilized in the network and will automatically assign the most optimized channel to each access point under its management. This greatly reduces RF interference and will allow the administrator to deploy APs more densely. -
Seamless mobility
Wireless clients can enjoy seamless and uninterrupted roaming from AP to AP if they are managed by the same DWS-3160, even if they are not in the same subnet. Because the DWS-3160 employs various mechanisms such as pre-authentication and keycaching, wireless users can freely roam the entire network without needing to re-authenticate. This allows tablet and smart phone and netbook computer users to travel freely within any premise covered by the DWS-3160's managed APs without having to worry about network connectivity, thus enabling for a truly mobile workplace.
- D-Link DWS 3160 - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 20 x 10/100/1000 (PoE) + 4 x combo Gigabit SFP
- Power Over Ethernet (PoE)
- PoE
- Performance
- Switching capacity: 48 Gbps
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- Routing Protocol
- RIP, static IP routing
- Remote Management Protocol
- SNMP 1, RMON, Telnet, SNMP 3, SNMP 2c, TFTP, SSH, CLI
- BOOTP support, VLAN support, IGMP snooping, port mirroring, IPv6 support, sFlow, STP support, RSTP support, VRRP support, MSTP support, QoS, DHCP server, MLD snooping, NAP, bandwidth control, LLDP support, DHCP relay, LACP, Traffic Control, DHCP client, GVRP
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 31 cm x 4.4 cm
- 5.2 kg
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- Performance
- 8K entries
- Routing Protocol
- Encryption Algorithm
- SSL
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+
- 20 x 10Base-T/100Base-TX/1000Base-T - RJ-45 PoE , 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 4 x SFP (mini-GBIC) , 1 x management RJ-45
- Power Device
- Internal power supply
- Voltage Required
- MTBF
- 282,541 hours
- FCC Class A certified, UL, VCCI, C-Tick, cUL, ICES-003, CB
- 44 cm
- 31 cm
- 4.4 cm
- 5.2 kg
- 0 °C
- 50 °C
- 10 - 90%
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90%
