The DCS-6915 Outdoor 20X Full HD WDR Speed Dome Network Camera is a high-definition professional surveillance and security solution suitable for small, medium, and large enterprises. The DCS-6915 features a 3 megapixel sensor capable of Full HD 1080p resolution, allowing for very clear surveillance footage to be taken. The powerful 20X optical zoom and 10X digital zoom ensure that you can see even the smallest details with ease.
Proportional pan, tilt, and zoom speeds
Adjusting the camera is painless since the pan and tilt speed is proportional to the optical zoom ratio of the camera. When the camera zooms in, the panning speed is automatically slowed to improve camera tracking and controllability. PTZ presets allow the camera to monitor specified areas along predefined paths.
- D-Link DCS-6915 Outdoor Speed Dome Full HD Camera - network surveillance camera
- Network surveillance camera - pan / tilt / zoom - outdoor - vandal / waterproof
- 2.6 kg
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Optical Zoom
- 20 x
- Optical Sensor Type
- CMOS - 1/2.8"
- Minimum Illumination
- 0.8 lux - colour - F1.2 , 0.08 lux - B&W - F1.2
- Focal Length Control
- Motorized zoom
- Focal Length
- 4.7 mm - 84.6 mm
- Focus Adjustment
- Automatic
- Lens Iris
- Auto iris
- Panning Range (degree)
- 360
- Tilting Range (degree)
- -90 to +90
- Ethernet 10Base-T/100Base-TX
- SD-card slot, heater, ONVIF support, built-in cooling fan, auto backlight compensation, multi-streaming
- Environmental Parameters (operating)
- 0 °C - 50 °C; 20 - 80% (non-condensing) relative humidity
- Wired
- 2.6 kg
Camera
- Colour - Day&Night - pan / tilt / zoom - outdoor - vandal / waterproof
- Digital Video Format
- MJPEG, H.264
- Digital Zoom
- 10
- Supported Image Formats
- JPEG
Image Sensor
- CMOS 1/2.8"
Lens Construction
- Motorized zoom
- Optical Zoom
- 20 x
- Focal Length
- 4.7 mm - 84.6 mm
- Lens Iris
- Auto iris
- Focus Adjustment
- Automatic
Panning
- Range (degree)
- 360
- Speed (degree/sec)
- Up to 300
Tilting
- Range (degree)
- -90 to +90
- Up to 200
- Network Interface
- Network Protocols
- DHCP, DNS, FTP, HTTP, SMTP, TCP/IP, UDP/IP, ICMP, HTTPS, IPv4, IPv6, RTCP, IGMP, 3GPP/ISMA
- Interfaces Details
- 1 x network - Ethernet 10Base-T/100Base-TX
- FCC, IP66
- Power Device
- Power adapter - external AC 100/230 V 65 Watt
- Software Included
- Drivers & Utilities
- 0 °C
- 50 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.93 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.58 |
