D-Link 20km Long Range Wireless AC Bridge
Quicklinx: J7JNWS00 Mfr#: DAP-3712
£181.83 ex VAT
£218.19 inc VAT
The DAP-3712 is the essential solution in providing connectivity to previously believed impossible-to-reach areas. Industry leading core technologies, especially designed for long distance coverage, bring high-speed connectivity to rural areas and challenging terrain equivalent to that of a wired connection.
  • TDMA technology cuts through the chatter, creating even stabler coverage
    The DAP-3712 transmission capability is augmented thanks to its integrated Time Division Multiple Access (TDMA). Everything works more efficiently on a schedule, and the DAP-3712 is no different: TDMA creates a schedule for multiple connected clients to work to. Senders and receivers get their own time slot for transmissions. This eliminates hidden node data collisions, in turn maximizing airtime efficiency, significantly cutting down interference and making for a highly scalable solution.
  • Form without sacrificing function
    It can be hard to look good while still being functional. Yet the DAP-3712 strikes the balance just right. The smooth case in crisp white makes for a low-key form that can effortlessly fit any outdoor setting without drawing attention. Being as functional as it is well-formed, it champions an IP66 rating, fighting dust and repelling water, all while maintaining its unassuming looks.
  • Cutting edge hardware makes the previously impossible, possible
    The DAP-3712 features state-of-the-art hardware, including a high-gain 23 dBi directional antennas. This powerful antenna effortlessly extends high-speed coverage to distances of up to 20 km away.
  • Discreet deployment that's hassle-free with Power Over Ethernet (PoE)
    Power sockets can be tricky to come by, especially in outdoor deployments. But PoE makes for easy installation and a simple, clean setup. No need to run extra power lines, no added hassle when configuring your hardwiring, and no more cable clutter.
D-Link DAP-3712 - wireless bridge - Wi-Fi 5
Wireless bridge
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
5 GHz
Performance
Bandwidth: 20 MHz , Bandwidth: 40 Mhz , Bandwidth: 80 MHz
Power Over Ethernet (PoE) Supported
PoE
DC 48 V (PoE)
37.2 cm x 24.1 cm x 37.2 cm
900 g
Wireless bridge
37.2 cm
24.1 cm
37.2 cm
900 g
External
Wireless
Data Transfer Rate
867 Mbps
Network / Transport Protocol
NTP, DHCP
Routing Protocol
Static IP routing
Remote Management Protocol
NTP, DHCP
Frequency Band
5 GHz
Max Range Open Space
20 km
Performance
Status Indicators
Signal strength
VLAN support, Syslog support, MAC address filtering, firmware upgradable, Auto Channel Select (ACS), reset button, Time Division Multiple Access (TDMA), WDS access point, dustproof, waterproof, 8KV surge protection
Encryption Algorithm
WPA2, 128-bit AES
Authentication Method
Radio Service Set ID (SSID)
IEEE 802.11i
Aerial
Directivity
Directional
Gain Level
23 dBi
1 x 1000Base-T (PoE) - RJ-45
FCC, IP66
PoE
Power injector
DC 48 V (PoE)
15 Watt
-40 °C
65 °C
0 - 90%
Brand: D-Link
